3D Printed Finger Line Release for Sling Speargun Seac Sub Killer 60
About: I studied Electrical Engineering and a lot of other things. I'm always driven by my passions. Please visit also my Youtube channel.
Welcome to my "ible" #36.
Safety, first!
The finger line release I've designed doesn't modify in any way the safety of my speargun. In some countries (Italy for example), you have to be 16 years old to use a speargun, that is still remains a potentially dangerous weapon and has to be treated with respect. "Never walk about with a loaded speargun or leave a loaded gun lying about. Always unload before leaving the water. Never point a speargun at anyone, and take care when firing in murky water, you may easily hit one of your companions and cause injury."
I've found my Seac Sub Killer 60 Sling Speargun in the attic (last time I went fishing with it, was 25 years ago),and I decided to restore it.
I've bought 2 brand new rubber bands, but I realized that the finger line release was missing (the Killer 60 wasn't equipped with it).
I've found a brilliant solution to this problem in an underwater fishing forum, suggested by Claudio.
By the way, many thanks for that!
http://www.pescasubapnea.com/pescasub/fai-da-te/pe...
Step 1: Print It... in 3D!
I've really liked this idea, but I didn't want to build it, as I thought that designing a 3D printing version of it, would have been much easier. After a bit of drawing, I've designed the finger line release and now the part is available here...
https://www.myminifactory.com/object/3d-print-line...
ready to be downloaded.
I've printed in ABS (in Nylon would have been better) and it's very robust, but I've printed twice to have a spare part...
you know, just in case.
Print in 3D your finger line release, here...
https://www.3dhubs.com/service/54199
Step 2: Install It on Your Seac Sub Speargun
Drill a hole close to the trigger, double checking the distance and the alignement.
You basically want to release the base of the finger, as soon as you press the trigger.
Add a M4 Nylon nut, a bolt and 2 washers, to attach the finger line release to the frame of the speargun.
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    • Tape Contest
      Tape Contest
    4 Discussions
    Brian M V
    6 months ago
    that's actually a really smart fix!
    looks like you have to press the trigger real deep to release..?
    RC Lover sanBrian M V
    Reply 6 months ago
    You can adjust the distance between the trigger and the finger line release at your discretion.
    My trigger has a bit of play, therefore I want be sure I'll release the line, only when the spear shaft has been released. If you like this project, please add it to your favorite... thanks!
    Marcelo_05
    6 months ago
    I wonder if this could be dangerous for any person to replicate.
    RC Lover sanMarcelo_05
    Reply 6 months ago
    Well, if you refer to the finger line release I've designed, it doesn't modify in any way the safety of the speargun. In some countries (Italy for example), you have to be 16 years old to use a speargun, that is still remains a potentially dangerous weapon and has to be treated
    with respect.
    about.
    and cause injury."
