3D Printed and Painted Godzilla
Introduction: 3D Printed and Painted Godzilla
About: Gambody is a premium 3D printing marketplace specialised in selling video game inspired and stylised 3D models for desktop 3D printers. All 3D models featured on the marketplace are high-poly, with detailed ...
Hey guys. It’s been a while since we last shared some content on this website. You can check our last Instructables here. Since then, we have had many interesting projects one of which we want to share it with you. As you probably know, this year Godzilla the movie celebrated its 25th anniversary. For this occasion, one of our customers from Taiwan 3D printed and painted a 38 cm tall Godzilla. This Instructables will focus on the printing and painting process.
Teacher Notes
Step 1: Get the STL Files
You will find on Gambody two versions of 3D printing files for Godzilla : one set consisting of 11 separate parts adapted for FDM 3D printers and 1 STL file for SLS 3D printers. The SLS version of the file will yield a 19 cm tall Godzilla.
Step 2: What Will You Need
3D printing equipment and materials:
  • Infinity X1, Anycubic i3 Mega 3D printers
  • PLA material
  • Nippers
  • Sanding paper
  • Primer
  • Oil paints
  • Acrylic paint
  • Spray paint
  • Painting brushes
The figurine was printed at a layer thickness of 0.12mm, infill of 15%, printing speed of 30, and the total time took about 400 hours.
Step 3: Post 3D Printing Processing
First, remove all supports off the model with the help of the nippers. Also, use sanding paper to smooth out the upper layer of the miniature. Once done, apply 2-3 coats of primer as a smoothing finish.
Step 4: Assemble All Parts
Once done with printing, Hassemble all parts. The video will make assembling of 3D printing figurine easier.
Step 5: Star Painting
Use dark green and dark blue to paint the dorsal area of the Godzilla. For this part, a small airbrush might come in handy. Spray the dark green from 15cm distance of the model. Avoid applying too much of it. If you do, the paint will run and this is not the effect you want to achieve. Work your way from the darker to the lighter colour.
Step 6:
Apply dark blue at the tips of the dorsals and with a brush, apply lighter blue brush strokes. It should look like a gradual ombre effect. Work your way, applying brushstrokes of dark green and blue across the figurine.
Step 7: Last Step
Paint the eyes and mouth of the Godzilla with rusty red. And you’re done. This Godzilla comes also with a support base. And… you’re done!
This Instructable was written with the help of our friends from Taiwan who 3D printed and painted Godzilla (you can find the original text here) and agreed to share their work here.
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
