3D Snowflake
A simple homemade decorating idea.
Supplies:
6 Pieces of paper
Scissors
Clear tape
Stapler
Teacher Notes
Step 1: Make Your Paper Square
In this example, we're using regular computer paper so the first thing we need to do is make it square. To do this, take one corner of your paper and fold it over to the other side to make a triangle and cut off the excess.
Step 2: Fold Your Paper Into a Smaller Triangle
Once you've cut off the excess you are left with a triangle. Fold your paper in half to make a smaller triangle.
Step 3: Cut Five Evenly Spaced Slits Into Your Triangle
Begin cutting at the final fold of your triangle and cut toward the double folded crease.
When you unfold the paper it should look like the picture above.
Step 4: Unfold the Paper Until You Are Back to Your Square With the Cut Lines
Step 5: Roll the Innermost Pieces Together and Adhere With Clear Tape
Step 6: Flip the Paper
Turn the paper over so the pieces you just taped together are face down.
Step 7: Tape the Next Section Together
Grab the next two pieces and roll them together. Adhere with clear tape.
Step 8: Repeat Steps 6 and 7 Until All the Pieces Are Taped Together
Step 9: Repeat Steps 1 Through 7 Five More Times
Repeat steps 1 through 7 five more times until you have 6 separate snowflake petals.
Step 10: Arrange the Six Pieces Together Until You Like the Way It Looks
Step 11: Staple the Center Pieces Together Two at a Time
Step 12: Staple the Three Pieces Together
This is the tricky part. You need to get all three pieces together and staple them without bending the rest of the petals. This works best with a small stapler so you can get your hand in there. If it ends up a little wonky don't worry, the next step will fix it.
Step 13: Adhere the Edges
We need to adhere the outer edged of each petal to each other to make it hold it's shape. To do this we're going to roll a small piece of tape together (or use double sided tape, if we have it).
Step 14: Display
You can now display your new snowflake as a centerpiece or hang in a window.
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Cardboard Speed Challenge
    seamster
    26 days ago
    Very nice! : )
