3d Map
135
This is the fastest and super easy one-day school project.
Supplies:
A4 sheet and pencil (since I had an old map lying around I'm using that)
Newspaper
Paper tape
tissues
White craft glue (fevicol)
Paint (light green, dark green, light yellow dark yellow, white, blue)
scissors
Teacher Notes
Step 1: Thickness
To create the thickness we can either tape the backside of paper using paper tape or stick another sheet of A4 size sheet.
Using scissor Remove the extra portion of paper tape
Step 2: Roll and Tape It
Land isn't exactly plane.
so to create a mountainy effect and irregular surface, we are going to smush paper into small balls and tape it using paper tape to the land region.
Step 3: Glue and Water
take a bowl of water mix white crafting glue and apply on the model before sticking the tissues on to the surface using this tissue we can give details to the land
Step 4: Paint It
I recommend painting the model after it is dry or if your in hurry u can just paint but the color may fade a little after the map is dry
first: I used a toothbrush to spray light green.
second: used dark green to paint the land using cotton or tissue
third: used light yellow at few areas to bring the dry look
fourth: used dark yellow to get bit of mountainy effect
fifth: used white to represent snowy effect
For the ocean paint it in dark blue and and apply some of the white paint randomly to create water effect
and tad-da we have our map ready
Step 5: Signs
In case we need signs to represent gold mine or the last historic treasure found we can draw it in a piece of paper cut them and stick on the map, It gives a good impression.
Art Skills Challenge
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    Akm1014
    2 months ago
    I love this idea. All the supplies are items I have around the house and I can easily incorporate this into my children’s current geography project. Thank you for sharing!
