5 Life Hacks With Screws You Should Know
About: Hello, everyone! I'm Dr. Hacker and welcome to my channel. I'm a DIYer who loves to share amazing life hacks, cool projects, and science experiments. Hope you like my videos! Please subscribe to my channel ...
You will be amazed when you find out some of the things you can do with screws. The possibilities are endless!
Jump into any section:
How to Tighten or Loosen a Bolt when You don’t have the correct Wrench
(00:12) Hold the extra bolt horizontally over the bolt in question and then just screw on the nut until you have a nice tight grip on that annoying first bolt. Instant wrench! This trick can also work if you don’t have any wrenches at all.
(01:07) Having an oversized wrench, you may also use a flat blade screwdriver to fill a gap between the bolt and the wrench.
(01:43) Turn Any Screwdriver Into a Magnetic Screwdriver With One Simple Trick
Magnetic-tipped screwdrivers are extremely useful, but there’s no need to buy a new set when you can convert your existing ones for free. Instead of buying new sets of magnetic tipped screwdrivers, you can simply attach a magnet to your existing screwdriver.
(02:37) Remove a Stripped Screw with a Rubber Band
A rubber band may provide enough grip to remove a stripped screw. Place a wide rubber band in between the screwdriver and the screw, then apply hard, but slow force as you turn.
(03:36) How to Sharpen a Paper Cutter Blade with a screw and a nut
Please leave your comments in the comments section. Your feedback will be appreciated.
Thanks for watching!
Like ! Share ! Comment ! Subscribe !
Teacher Notes
    • Indoor Lighting Contest
    • Metal Contest
      Metal Contest
    • Make It Fly Challenge
