5-Minute Project: Drill-Powered Skateboard
141,800
122
117
Introduction: 5-Minute Project: Drill-Powered Skateboard
Do you have a skateboard that is gathering dust in the corner of your garage? Breathe some new life into those wheels by zapping them with some volts. Specifically, attaching a battery-powered electric drill to the front of your skateboard will provide effortless nosegrinding and endless hours of fun.
Three factors will enhance your battery-powered skateboarding:
1. More Volts. Higher voltage battery-powered drills (at least 9.6V) will provide more minutes of skateboarding fun.
2. Greater Torque. Drills that can generate more torque will be able to move, ahem, heavier riders.
3. Big, Bad Rubber Wheel. The more rubber that meets the highway, the higher the performance.
Teacher Notes
Step 1: How to Make SkateBored
5-minutes
Cost: $2.80
Very Easy
Parts List
  • Skateboard (salvaged)
  • Battery-Powered Drill; at least 9.6V (salvaged)
  • 25-inches of 1/2-inch PVC Schedule 40 (1.00)
  • (2) 90-degree Elbow PVC Schedule 40 (.90 each)
  • Large Rubber Wheel (salvaged)
  • Cable Ties
Step 2: Pop a Wheelie
Remove the right front wheel from the skateboard's axle.
Step 3: Open Up, Wide
Open the chuck's jaws (those are the steel fingers inside the chuck that typically hold the drill bit) of the battery-powered drill to its maximum aperture. The chuck should fit easily and loosely over the skateboard's front right axle.
Step 4: Chuck It
Slip the large rubber wheel over the drill's chuck. Use a rubber wheel that has a large enough diameter to lift the drill head up off of the ground. This wheel should also be a very snug fit over the chuck.
Step 5: Be a Supporter
Build a support for the drill from the PVC Schedule 40 pieces. The lengths of these pieces will vary depending upon your make/model of drill. In this example, three pieces measuring 15 3/8-, 6 3/4-, and 2 1/2-inch were used. The longest piece is inserted into one of the elbows followed by the shortest piece and another elbow. Finally, the medium length piece is added to the second elbow. You shouldn't have to glue the PVC pieces together--a friction fit is good enough for this project.
Step 6: Lash It
Attach the completed support to the top of the skateboard deck with cable ties. A correctly attached support should hold the drill's handle off the ground. Tidy up your assembly and mount up.
Step 7: Hit the Road, Jack
Don your protective clothing, install a fresh battery, squeeze the drill's power trigger, and it's off to the races.
Notes:
  • In right-wheel installations the drill's motor should be set for maximum torque and forward motion. If you opt for a goofy ride (aka left-wheel installation), be sure to switch the drill's motion to reverse.
  • Install two electric drills for greater power. Make sure that you switch the left-hand drill to reverse motion (see above note).
  • Lightweight riders can ride the SkateBored solely on battery power. Heavier riders will have to kneel on the deck and kick off with the other foot.
  • The SkateBored will eat up rubber wheels. Use special off-road R/C truck tires for the best results.
  • Alternatively, if you can't find any suitable rubber wheels, try wrapping the chuck with several layers of duct tape.
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Finish It Already Speed Challenge
    • First Time Author Contest
    117 Discussions
    RomanK82
    RomanK82
    2 years ago
    Nice! This is on my list of things to do next.
    li789
    li789
    10 years ago on Step 7
    what skateboard did you use because mine didn't work
    chan2005
    chan2005
    Reply 6 years ago on Step 7
    mine didn't either. fixed axle
    Odziz
    Odziz
    12 years ago on Introduction
    This goes one step further, a drill-powered bike. 'This Old House' beats 'PopSci' hands down!
    Would be quite neat if it was combined with the 8020 Chopper.
    8020 Chopper assembly
    KBHELLSPAWN
    KBHELLSPAWN
    Reply 12 years ago on Introduction
    HEY WHAT DO YOU CALL THAT wierd LOOKLNG BIKE THAT GUY IN THE VID WAS RIDING? ANYONE
    Labot2001
    Labot2001
    we've always called them monkey bikes, but th term can also be used to describe a little motor-driven bike or dirtbike
    geoslim13
    geoslim13
    make mag did an article on how to do so in either issue 20 or 21
    rocker_man_2010
    rocker_man_2010
    Reply 11 years ago on Introduction
    HAy MAke IT, That's what this site is for is to build things yourself ---T
    Tmac121
    Tmac121
    8 years ago on Introduction
    This doesn't work on a real skateboard. the axle shouldn't rotate.
    retrotimelord
    coulden't you just take out the motor and attach it up to da wheel then put a foot peadal switch on the the battery and solder all dat up???( a little more complicated)
    lilybadea
    lilybadea
    9 years ago on Introduction
    Great Idea and very innovative. This is very best idea to bring in use the waste. now like this one, the skateboard with the power of battery and drill machine have become a nice play thing for children.But i am thinking can we do this for kick scooters as well . Am interested in trying this idea once to my skaeboard. This will be fun.
    dragonfathom
    dragonfathom
    9 years ago on Step 7
    It'd be better with a system that lets you stand up.
    jsilve1
    jsilve1
    could you attach a stronger drill to a bike
