5200 Double Transistor Bass Audio Amplifier
About: Share diy projects to those who have the same hobby with me
Hii friend,
Today I am going to make a circuit of bass audio amplifier using 5200 double transistor.
Let's get started,
Teacher Notes
Step 1: Take All Components As Shown Below
Components required -
(1.) Transistor - 5200 x2
(2.) Battery - 9V x1 (9-12)V
(3.) Battery clipper
(4.) Speaker
(5.) Capacitor - 25V 220uf x1
(6.) Resistor - 1K x1
(7.) Aux cable (Single chanel)
Step 2: Transistor - 5200
This is the pins of this transistor.
Step 3: Connect Both Transistors
Firstly we have to connect both transistors like as picture.
Solder Base pin of transistor-1 to base pin of transistor-2,
Collector pin of transistor-1 to collector pin of transistor-2 and
Solder emmiter pin of transistor-1 to emmiter pin of transistor-2 as you can see in the picture.
Step 4: Connect 1K Resistor
Next we have to connect 1K resistor to the transistor.
Solder 1K resistor between Base pin to collector pin of transistors as you can see in the picture.
Step 5: Connect 220uf Capacitor
Next connect 25V 220uf capacitor to the circuit.
Solder +ve pin of electrolytic capacitor to Base pin of transistors.
Step 6: Connect Aux Cable Wire
Connect Left/Right wire of aux cable to -ve pin of electrolytic capacitor and
solder -ve wire of aux cable to emmiter pin of transistors as solder in the picture.
Step 7: Connect Speaker Wire
Next connect -ve wire of speaker to collector pin of transistors.
Step 8: Connect Battery Clipper Wire
Solder +ve wire of battery clipper to +ve of speaker wire and
Solder -ve wire of battery clipper emmiter pin of transistors as you can see in the picture.
Step 9: Connect Battery
Our audio amplifier circuit is completed so connect battery to battery clipper and plug-in aux cable to phone and play songs.
NOTE : Use 12V DC Input power supply to get best output audio.
This type we can make audio amplifier using 5200 double transistor.
Thank you
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
