6 String Bass Guitar Made With Wood From Recycling Been
5,659
57
9
About: I am a physicist. I am a developer. I like to build musical instruments.
Few days before I finished this
bass guitar and about it I have a dream. In this dream, Les Claypool takes my finished bass guitar, play some, and said "Nice bass, but sometimes I would like to play on 4 string one". After that, my worries about, will this bass have a nice sound and stuff disappeared.
Long Story. At school, I want to create an 8 string guitar and play on it. It's done. When I studied at the University me and my friend played together and dreamed about a rock band. I decided that I will play the bass. I decided to buy some cheap 4 string bass. It hadn´t so good sound and I learned to play not enough. But I always dreamt about a 6 string bass.
After my first handmade guitar, and bass, I figured out that mostly all depends on the skill, but the dream about 6 string bass was not achieved. And, on Instructables, it's was going to be the first 6 string bass guitar.
So, I decided to make the 6 string bass.
Teacher Notes
Step 1: Drafting, Dreaming, Planing
One day, while I was taking my son from the kindergarten, I saw that
someone throw away cathedra.
That cathedra had very nice and tasty pieces of oak. I took it home and s started to think about the new project.
On my job sometimes I draft sketches of the new bass. The best sketch I have scanned, imported to CorelDraw and created a full-size schema.
And, I want to set on guitar squares, like on a chessboard. So I drafted it on paper. For this squares, I have wood from the previous project, rest of wenge fretboard.
Mine parameters:
scale length: 864 mm
26 frets (I plan 27, but make a mistake in calculation)
6 string
Neck through
2 pickups
Step 2: Materials and Instruments
Instruments:
- drill
- little carpenter’s plain.
- a lot of sandpaper :)
- board with sandpaper
- chisel 6 mm
- clamps and bricks
- small hummer
- handmade drill-to-router converter
- chair leg (for frets instaling)
Materials:
- wood from recycling bin ( oak, birch, beech)
- fretboard from recycling bin (probably it is ash)
- head machines, bridge, resistors, condensers, pickups - some noname from China
- carbon toss rods and adjusting toss from China to
- nut - VIP bakelite, perhaps from old iron, which I found not around recycling bin, but on the train rails
Step 3: Combining
I planned to make neck-through
bass, to do that I needed a long piece of wood. In the piece of wood needed for length, I have the only birch, but with bark. I think it's some like 4 or 5 level quality of the wood :). So, this wood can't be the mainframe.
Also, I have two beechen table legs. I decided to mount them together. They were of a rounded section, that's why I made some square in the section. After, I made them already squared.
After gluing together two pieces of birch and beech I figured out, that I need more width. I had two pieces of oak, and I calculated the trapezoidal shape of the neck. So I glued to my workpiece two pieces of oak write on the place, where I needed to.
I hadn´t enough width and deep of guitar head. Width I increased adding little pieces of birch.
Deep I increase, as for me in the pretty witty way. The guitar neck has to have some inclination. So I cut wood for incline and cut off peace glue on another side (unfortunately, I didn't take photos of this part of work).
Actually, It looks like I took every wood I saw until I glued all together to the whole guitar
Step 4: Cheesing and Shaping
For black squares, I use rest of wenge. For white squares, I
used mostly beech. There were many different pieces which I can glue together and make a few squares.
Step by step I glued squares to the surface side by side. Some squares have come out of the shape, I cut it.
When the main shape was done, I started the second part of shaping.
I took my drill, put on it sandpaper disk with the biggest abrasive I have and did a wrily smooth shape.
My masterpiece had a lot of little holes and bugs, I needed to make them. I made the mixture with glue and sawdust, and fill up all of them.
Little scratches I fixed up with super glue and sandpaper. I dropped a little drop into the scratch and sanding it
Step 5: Make Pickup Hols and Other
For pickups, I made holes with the drill. At first, I made many 10 mm
holes. After I use a handmade drill-to-router converter.
The same I did with electronics niche.
Step 6: To Paint or Not to Paint
I want to make the guitar darker, so I decided to use black wood stain. It
looks like an experiment.
I bought a black wood stain, put hold gloves (I understand that these gloves have holes later when I look to my hands :) ).
After painting the guitar has a strange grey color. I don't know, did I lose or win with this decision.
Step 7: Install Toss Rod and Carbon
I had made grooves for toss rod and carbon rails with the chisel. For
carbon rails, I have used 8 mm chisel sharped to 6 mm. As you can see in the photo, the groove for toss rod is symmetrical enough and for carbon rails not. I made this because of some reasons.
As I wrote earlier, I used some birch of very strange quality, central beech is tough enough. So I have this not parallel, perfectionist hate, the wood and I decided to strengthen the construction by losing the week wood.
When grooves for carbon was done, I glued carbon rails with epoxy.
Step 8: Fretboard
When it was a turn to the fretboard, my contract on my job was
broken. I dropped away from the idea to make palisander or some else exotic wood.
So I started to find alternatives. I had remained that I found nice white wood, it looks like an arch, from the old sofa. And I know that sometimes use the arch for the fretboard. I decided to make the fretboard by myself.
I took the board, and slitted it. I got two not way flat pieces of wood. And this workpiece was not wide enough. I had no way out, I needed to make the fretboard with pieces. And I made it.
My fretboard wasn't flat enough. For flatting fretboard, I use my main instrument: desk with sandpaper.
When the fretboard was flat, I round it with my round block, which based on 26" bicycle rim.
After I have covered all with a layer of flaxseed oil. After two weeks I marked frets, cut grooves for them, end installed with glue.
Tip for future: better use some polymer based lacquer for a fretboard, like that, set layer of lacquer, after drying sand it. Your wood fiber will be glued together, and you can polish it better.
I had hoped that flaxseed oil does made this, but it didn´t happen.
Step 9: Finishing and Installing All
After clean grinding, I figured out that I needed to think down the bridge.
So I do that, and I
needed clean grinding again.
Then I covered all with flaxseed oil. It needs a long time for polymerization. After I covered all with yacht lacquer, 5 times.
Then I polished guitar and installed all furniture and electronics.
For shielding, I used the food foil. It is the efficient and cheap method. One wire without isolation connected to ground, strings, through the bridge, pickups reostats.
Step 10: Look and Sound
So I finish it. I have 6 strings bass guitar. It is a childhood dream :)
Audio Contest 2018
Audio Contest 2018
Be the First to Share
    • Made with Math Contest
    • Cardboard Speed Challenge
    • Multi-Discipline Contest
    9 Discussions
    JamesC342
    11 months ago on Step 3
    The author's English is terrible. Why wasn't this edited by a native English speaker before being posted. Can barely understand what the hell he's trying to say
    krwrightJamesC342
    Reply 11 months ago
    Cut the man some slack. He writes better English than I write, well, anything but English.
    KatodJamesC342
    Reply 11 months ago
    I know. I am working on learning english.
    Next time i will send you, if you dont mind :)
    And thank you for comment
    ChrisH117
    11 months ago
    Fantastic project and it looks and sounds great! Let's start a band.
    KatodChrisH117
    Reply 11 months ago
    thank you :)
    Lets start!
    It will be first band which create handmade music :)
    technovative
    1 year ago
    Much artistry, ingenuity, and craftsmanship went into this build. Eye-catching and seems quite playable. You've presented your fantastic creation well in this informative article.
    Katodtechnovative
    Reply 1 year ago
    Thanks a lot!
    It's wery playeble bass :)
    RobC184
    Question 1 year ago
    This looks awesome. But I'm more interested in your drill-to-router converter. (The bass is cool but I don't play.) Can you do an instructable on that please?!
    1 answer
    KatodRobC184
    Answer 1 year ago
    Hi. Thanks a lot for this comment.
    I can make another one converter, but it is very simple. I will send you a few photos of this.
