Introduction: 7 Segment Display Common Anode Counter Arduino
About: My name is Nour Bouzid
In this instructable, I'm going to show you how to control a 7 segment display ( common ANODE) who would count from 0 to 9.
Step 1: 1. the Cables
Alright, the branching could be pretty tricky when you're dealing with a common anode 7 segment display. For my case, I have a :
KINGBRIGHT SA04-11hwa.
First look for the two anode ports for me it was the 2 and 3. If you don't know how to do that there are two ways to figure out your anode ports you can either look for your 7 segment display datasheet online or you can connect a wire to the grd of the arduino and then put a connect a positive wire and try to find your anodes. When you finally did that here's what I did :
Led1 : pin 3
Led2 : pin 4
Led3 : pin 5
Led4: pin 6
Led5 : pin7
Led6: pin 8
Led7 : pin9
Led8 : pin 10
ANODE : pin 2 (basically you put the two anodes together and back to pin 2) in the picture my two anodes are the red wires
Step 2: 2. the Code
here's the code for the counting from 0 to 9
// 7 bit light with common anode in series from each light
const int ANODE = 2; // common anode pin
const int LED1 = 3; // led 1 going right to left top to bottom
const int LED2 = 4; // pin for led 2
const int LED3 = 5; // pin for led 3
const int LED4 = 6; // pin for led 4
const int LED5 = 7; // pin for led 5
const int LED6 = 8; // pin for led 6
const int LED7 = 9; // pin for led 7
const int LED8 = 10; // pin for led 8
int DELAY = 0; // so it happens only 3 times
void setup() {
pinMode(ANODE, OUTPUT); // common anode is obviously an output
pinMode(LED1, OUTPUT); // led are output for low will be on
pinMode(LED2, OUTPUT); // led 2 is output
pinMode(LED3, OUTPUT); // led 3 is output
pinMode(LED4, OUTPUT); // led 4 is output
pinMode(LED5, OUTPUT); // led 5 is output
pinMode(LED6, OUTPUT); // led 6 is output
pinMode(LED7, OUTPUT); // led 7 is output
pinMode(LED8, OUTPUT); // led 8 is output
void loop(){
if (DELAY == 300){
delay(100000);
digitalWrite(ANODE, HIGH); // anode is recieving power
digitalWrite(LED1, HIGH); // stops power to led 1
digitalWrite(LED2, HIGH); // stops power to led 2
digitalWrite(LED3, HIGH); // stops power to led 3
digitalWrite(LED4, HIGH); // stops power to led 4
digitalWrite(LED5, HIGH); // stops power to led 5
digitalWrite(LED6, HIGH); // stops power to led 6
digitalWrite(LED7, HIGH); // stops power to led 7
digitalWrite(LED8, HIGH); // stops power to led 8
delay(1000); // delays before starting
digitalWrite(LED1, LOW);
digitalWrite(LED2, LOW);
digitalWrite(LED3, LOW);
digitalWrite(LED5, LOW);
digitalWrite(LED6, LOW);
digitalWrite(LED8, LOW);
delay(500); // delays before starting
delay(500);
delay(500);
delay(500);
digitalWrite(LED4, LOW);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
And that's it, good luck. If you have a question comment below , I'll answer as fast as possible
Make it Glow!
Make it Glow!
