99¢ Foppy Power Connector LED Bouquet Jawn
Introduction: 99¢ Foppy Power Connector LED Bouquet Jawn
This is a bit of junk art, patched together with old floppy drive power connectors, a spare USB printer cable, and less than 1$ of LED's & Resistors.
Step 1: Gather Your Supplies
  • 20 LED's, Slow Flashing 5MM Diffused 7 Color
  • 20 47Ω Resistors
  • 10 Floppy Power Connectors
  • Heat Shrink Tubing
  • 5V Cell Phone Charger
  • USB Cable
  • Soldering Iron
  • Wire Strippers
Step 2: Start Stripping
  • Strip a generous amount (at least an inch) of cable from the base of the positive and negative cables
  • Make a second cut on the positive cables and slide it down as shown
  • Twist the negative leads together
Step 3: Solder Resistors
  • Cut the positive cable in half where you exposed the wire.
  • Solder Resistors inline as shown
  • Visually inspect or test your soldering before adding heat shrink
Step 4: Insert LED's to the Power Connectors
  • Add LED's to the power connectors, keep track of polarity
  • Common the negative (short leg) by twisting together, as shown
  • Fold the positive (long leg) up the side, as shown
Step 5: Prep Your USB Cable
  • Cut the end from a USB cable and strip the wires
  • Cut the data cables at different lengths to prevent short circuits.
  • Check the power cables for polarity, don't trust colors.
Step 6: Solder Your Bundles
  • Twist the Positive leads together and solder them
  • Twist the Negative Leads together and solder them
  • Solder the the power cables from the USB cable to the respective ends
  • Add heat shrink to the bundles
Step 7: Cleanup and Troubleshoot Loose Conections
  • Power up your Bouquet from a wall cell phone charger or a USB power bank.
  • Tap the LED's, if the color changes back to red or off, you need to fix the connection.
  • The Negative cables should have 50% less problems. (I had zero bad negative connections)
  • Twist some solid core cable and stuff it up the bottom to insure good contact.
  • Snip the solid core cable and positive leads flush, as shown.
  • Leave the negative exposed
Step 8: Make a Base, Because You Are Done.
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
