A DSLR Camera Made From 6367pcs 5mm Magnetic Balls
About: Unleash your imagination and creativity
A DSLR camera (digital single-lens reflex camera or digital SLR camera) is a digital camera that combines the mechanisms of a single-lens reflex camera and the optics with a digital imaging sensor. A DSLR camera uses a mirror that reflects the light coming from the camera lens to an optical viewfinder or the image sensor.
In this post, I show you how to build a DSLR camera from 6367pcs 5mm magnetic balls.
Supplies:
856 pieces 5mm light black magnetic balls
966 pieces 5mm silver magnetic balls
1800 pieces 5mm nickel magnetic balls
2745 pieces 5mm black magnetic balls
Teacher Notes
Step 1: Make a Chain With 34 Balls.
Step 2: Connect 17 Chains of 34-ball Chain Together to Make a Sheet.
Step 3: Join the End of the Sheet of 17 X 34 Balls Together.
Step 4: Connect the Top Chain of the Sheet Together and Fold the Sheet to Make It Flat.
Step 5: Make a Chain With 40 Balls.
Step 6: Connect 17 Chains of 40-ball Chain Together to Make a Sheet.
Step 7: Place the Folded Sheet of 17 X 34 Balls on Top of the Sheet of 17 X 40 Balls.
Step 8: Wrap the Sheet of 17 X 40 Balls With the Sheet of 17 X 34 Balls.
Step 9: Make a Chain With 46 Balls.
Step 10: Connect 17 Chains of 46-ball Chain Together to Make a Sheet.
Step 11: Place the Wrapped Sheets on Top of the Sheet of 17 X 46 Balls.
Step 12: Wrap the Sheet of 17 X 46 Balls With the Wrapped Sheets.
Step 13: Make a Chain With 52 Balls.
Step 14: Connect 17 Chains of 52-ball Chain Together to Make a Sheet.
Step 15: Place the Wrapped Sheets on Top of the Sheet of 17 X 52 Balls.
Step 16: Wrap the Sheet of 17 X 52 Balls With the Wrapped Sheets.
Step 17: Make a Ring With 5 Balls.
Step 18: Make a Stack of 5-ball Ring With 18 Layers Height.
Step 19: Reverse the Chain to the Other Side and Make a Ring With 11 Balls.
Step 20: Make One More Layer Outside the 5-ball Ring Stack.
Step 21: Here Is the Complete Stack.
Step 22: Place the Stack on Top of the Wrapped Sheets.
Step 23: Make a Chain With 65 Black Balls.
Step 24: Connect 17 Chains of 65-ball Chain Together to Make a Sheet.
Step 25: Place the Wrapped Sheets With the Stack on Top of the Sheet of 17 X 65 Balls.
Step 26: Wrap the Sheet of 17 X 65 Balls With the Wrapped Sheets and the Stack to Make the Camera Body.
Step 27: Make a Sheet of 9 X 10 Balls.
Step 28: Make a Sheet of 8 X 10 Balls.
Step 29: Make a Sheet of 7 X 10 Balls.
Step 30: Make a Sheet of 6 X 8 Black Balls.
Step 31: We Now Have 4 Sheets.
Step 32: Place the Sheet of 9 X 10 Balls on Top of the Camera Body.
Step 33: Place the Sheet of 8 X 10 Balls on Top of the Sheet of 9 X 10 Balls.
Step 34: Place the Sheet of 7 X 10 Balls on Top of the Sheet of 8 X 10 Balls.
Step 35: Place the Sheet of 6 X 8 Balls on Top of the Sheet of 7 X 10 Balls.
Step 36: Make a Chain With 37 Silver Balls.
Step 37: Make a Ring With 6 Balls and 1 Balls in the Middle.
Step 38: Reverse the Chain to the Other Side and Loop the Chain Around the Circle.
Step 39: Reverse the Chain to the Other Side and Make One More Layer.
Step 40: We Need 2 37-ball Circles.
Step 41: Connect 2 Circles Together and Fold Them Together.
Step 42: Place the 2 Layers of the 37-ball Circle on Top of the Camera Body.
Step 43: Make 2 Chains of 3 Balls.
Step 44: Push the Chains to Make 2 Triangles.
Step 45: Insert the Triangle Inside the Gap of the Top of the Camera Body.
Step 46: Insert Another Triangle Inside Another Gap.
Step 47: Make a Chain With 19 Balls.
Step 48: Make a Circle With 7 Balls.
Step 49: Reverse the Chain to the Other Side and Make One More Layer.
Step 50: Make a Chain With 28 Balls.
Step 51: Make a Sheet of 7 X 4 Balls.
Step 52: Make a Sheet of 13 X 10 Balls.
Step 53: We Now Have an Optical Viewfinder, a Screen and a Control Button.
Step 54: Place the Optical Viewfinder on the Back of the Camera Body.
Step 55: Place the Screen on the Back of the Camera Body.
Step 56: Place the Control Button on the Back of the Camera Body.
Step 57: Make a Chain With 40 Black Balls.
Step 58: Connect 3 Chains of 40-ball Chain Together to Make a Sheet.
Step 59: Join the End of the Sheet of 3 X 40 Balls Together to Make a Circle.
Step 60: Slide the Balls on the Right Hand Up 1 Layer. Count 2 to the Right and Slide the Balls Up 1 Layer. Repeat Until You Slided the Complete Circle.
Step 61: Make a Chain With 40 Black Balls.
Step 62: Connect 3 Chain of 40-ball Together to Make a Sheet.
Step 63: Now We Have a Sheet of 40 X 3 Balls and a Circle.
Step 64: Wrap the Sheet of 40 X 3 Balls Around the Circle.
Step 65: We Need 4 Circles.
Step 66: Connect the Circles Together to Make the Lens Body.
Step 67: Make a Ring With 5 Silver Balls.
Step 68: Make a Stack of 5-ball Ring With 5 Layers Height.
Step 69: Reverse the Chain to the Other Side and Make One More Layer Outside the 5-ball Ring Stack.
Step 70: Make a Chain With 17 Silver Balls.
Step 71: Connect 5 Chains of 17-ball Chain Together to Make a Sheet.
Step 72: Place the Stack on Top of the Sheet of 17 X 5 Balls.
Step 73: Wrap the Sheet of 17 X 5 Balls With the Stack.
Step 74: Make a Chain With 23 Silver Balls.
Step 75: Connect 5 Chains of 23-ball Chain Together to Make a Sheet.
Step 76: Place the Stack on Top of the Sheet of 23 X 5 Balls.
Step 77: Wrap the Sheet of 23 X 5 Balls With the Stack.
Step 78: Make a Chain With 29 Silver Balls.
Step 79: Connect 5 Chains of 29-ball Chain Together to Make a Sheet.
Step 80: Place the Stack on Top of the Sheet of 29 X 5 Balls.
Step 81: Wrap the Sheet of 29 X 5 Balls With the Stack.
Step 82: Insert the Stack Inside the Lens Body.
Step 83: Turn the Lens Body Vertical.
Step 84: Add 1 Black Ball in the Gap Between the Top Balls. Repeat Until Complete the Circle.
Step 85: Make a Chain of 40 Black Balls and Place It Around the Balls We Just Added.
Step 86: Turn the Lens Body to the Other Side.
Step 87: Add 1 Silver Ball in the Gap Between the Top Balls. Repeat Until Complete the Circle.
Step 88: Make a Chain of 40 Silver Balls and Place It Around the Balls We Just Added.
Step 89: Connect the Lens Body to the Camera Body.
Step 90: Here Is the Complete DSLR Camera Made From 6367pcs 5mm Magnetic Balls.
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Multi-Discipline Contest
