Introduction: A Skateboard I Like
This skateboard is very practical, light, safe, easy to use and low in production cost.
Step 1: Step 1: Make the Bottom Plate
Select a square to adjust to 53 * 20 * 1
Step 2: Step 2 Production [double Warping]
Select the round roof to rotate 90 degrees along the Z
axis, and adjust it to 19.12 * 20 * 10.5
As shown in Figure 2-2, segment
Copy and paste the shape and adjust the hole to 19.62 *
20 * 5.27
Move up appropriately
Segmentation
Select a dome roof and set it as a hole as shown in Figure 2-5
Adjust to 18.6 * 20 * 8.9
Choose a rectangle of equal size
Combined split, set the resulting shape to hole
Figure 2-9 shows a warpboard obtained by combining and
dividing
Copy and paste to get the second warpboard, which
rotates 180 degrees along the X-Y side
Combination of two warps and plate surface
Get the whole layout as shown in Figure 2-10
Step 3: Step 3 Make Wheels
Select a tire
Adjust the tire to figure 3-2
Select a cylinder and multi-point cylinder to adjust to
17.5 * 5.4 * 5.3
Combine the shapes in 3-4
to get Figure 3-5
Figure 3-7 is obtained by combining figure 3-5 and
Choose a meta capsule
figure 3-6.
Using the combination of cylinder and polygon to get 3-8
Combine to get 3-9
Step 4: Step 4 [wheel Group]
Select a cube 4:3 in length and width
Place four orange cylinders (not tangent) at 4-2 corners
Get 4-3
Combine figure 3-8 with Figure 4-3 to get Figure 4-4
Combine a cylinder with Figure 4-4 to get figure 4-5
Figure 4-5 and figure 3-9 combine to get figure 4-6
Step 5: Step 5 [combination]
Copy and paste figure 4-6
The bottom plate and 4-6 are combined to get figure 5-1.
Step 6: Step 6 [decorations]
As shown in Figure 6-1, the height of the word maker
composed of letters is adjusted to 0.1.
The height of the word "BiliBili" composed of
letters is set to 0.1, as shown in Figure 6-2.
The figure of figure 6-3 is composed of a soft light box
and a rectangular and circular roof.
Height set to 0.1
Figure 6-4 is composed of two circles and three
rectangles
Cut the ring
get Figure 6-5
Combine figure 6-7 with figure 6-3 and figure 6-2 to get
figure 6-7
Combine figure 6-1, figure 6-7 and figure 5-1 to get the
finished product figure 6-8.
Skateboard Contest
