A Tape Dispenser Made From 3549pcs 5mm Magnetic Balls
About: Unleash your imagination and creativity
Tape dispenser is used for holding a roll of tape. It has a mechanism at one end to shear the tape.
In this post, I show you how to build a tape dispenser from 3549pcs 5mm magnetic balls.
Supplies:
435 pieces 5mm light black magnetic balls
570 pieces 5mm gold magnetic balls
924 pieces 5mm silver magnetic balls
1620 pieces 5mm blue-ish green-ish magnetic balls
Teacher Notes
Step 1: Make a Chain With 5, 3 and 4 Blue Balls.
Connect them together like the picture.
Step 2: We Need 11 Pieces.
Step 3: Connect Them to Make a Circle.
Step 4: Make a Chain With 5 Gold Balls.
Step 5: Connect the 5-ball Chain to the Circle We Just Made and Push Them to Make a Triangle.
Step 6: Make a Chain With 22 Light Black Balls.
Step 7: Connect the 22-ball Chain to the Tip of Each Triangle As Shown in the Picture Below.
Step 8: Make a Chain With 4, 3 and 5 Blue Balls.
Step 9: We Need 3 Pieces.
Step 10: Connect Them Together.
Step 11: Make a Chain With 5, 5 and 7 Blue Balls.
Step 12: Connect Them All Together.
Step 13: Make a Chain With 5 Gold Balls.
Step 14: Connect the 5-ball Chain and Push Them to Make a Triangle As Shown in the Picture Below.
Step 15: Make a Chain With 3 Blue Balls.
Step 16: Connect the 3-ball Chain As Shown in the Picture Below.
Step 17: Make a Chain With 13 Blue Balls.
Step 18: Connect the 13-ball Chain As Shown in the Picture Below.
Step 19: Now We Have 2 Parts of the Tape Dispenser.
Step 20: Let's Connect Them Together.
Step 21: We Need 3 Pieces.
Step 22: Stack Them Together.
Step 23: We Need 6 Pieces of the Other Part.
Step 24: Stack Them Together.
Step 25: Make a Ring With 5 Light Black Balls.
Step 26: Make a Stack of 5-ball Ring.
Step 27: Reverse the Chain to the Other Side and Make One More Layer With 11-ball Ring.
Step 28: Here Is the Two Layers Stack of 5-ball and 11-ball Ring.
Step 29: Make a Chain With 17 Silver Balls.
Step 30: Connect 6 Chains of 17-ball Chain Together.
Step 31: Wrap the Sheet of 6 X 17 Balls With the Two Layers Stack of 5-ball and 11-ball Ring.
Step 32: Here Is the First Layer of the Tape.
Step 33: Make a Chain With 23 Silver Balls.
Step 34: Connect 6 Chains of 23-ball Chain Together.
Step 35: Wrap the Sheet of 6 X 23 Balls With the 1-layer Tape.
Step 36: Here Is the Second Layer of the Tape.
Step 37: Make a Chain With 29 Silver Balls.
Step 38: Connect 6 Chains of 29-ball Chain Together.
Step 39: Wrap the Sheet of 6 X 29 Balls With the 2-layer Tape.
Step 40: Here Is the Third Layer of the Tape.
Step 41: Make a Chain With 35 Silver Balls.
Step 42: Connect 6 Chains of 35-ball Chain Together.
Step 43: Wrap the Sheet of 6 X 35 Balls With the 3-layer Tape.
Step 44: Here Is the Forth Layer of the Tape.
Step 45: Make a Chain With 41 Silver Balls.
Step 46: Connect 6 Chains of 41-ball Chain Together.
Step 47: Wrap the Sheet of 6 X 41 Balls With the 4-layer Tape.
Step 48: Here Is the Fifth Layer of the Tape.
Step 49: Make a Chain With 9 Silver Balls.
Step 50: Connect 6 Chains of 9-ball Chain Together.
Step 51: Insert the Separator to the 5th Layer of the Tape.
Step 52: Separate the 5th Layer to Add the Sheet of 6 X 9 Balls.
Step 53: Connect the Sheet of 6 X 9 Balls Together.
Step 54: Now the 5th Layer of the Tape Has Extra Balls to Make It Longer.
Step 55: Pull the Tape Out.
Step 56: Here Is the First Part of the Tape Dispenser.
Step 57: Insert the Tape Inside the First Part.
Step 58: Connect the End of the Tape to the First Part.
Step 59: We Need 3 Pieces to Make the Second Part of Our Tape Dispenser.
Step 60: Stack Them Together.
Step 61: Here Is the First Part of the Tape Dispenser.
Step 62: Connect the Second Part Together.
Step 63: Now Our Tape Dispenser Look Like the Picture Below.
Step 64: Make a Ring With 6 Balls and 1 Ball in the Middle.
Step 65: Reverse the Chain to the Other Side and Loop the Chain Around the Ring to Add 3 More Layers.
Step 66: Here Is the Cover of the Hole in the Middle of the Tape.
Step 67: We Need 2 Pieces.
Step 68: Turn the Tape Dispenser Vertical.
Step 69: Now Our Tape Dispenser Look Like the Picture Below.
Step 70: Let's Put the Cover on to Cover the Hole in the Middle.
Step 71: Now Our Tape Dispenser Look Like the Picture Below.
Step 72: Put the Cover on the Other Side.
Step 73: Now Our Tape Dispenser Look Like the Picture Below.
Step 74: Here Is the Complete Tape Dispenser Made From 3549pcs 5mm Magnetic Balls.
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Cardboard Speed Challenge
    2 Discussions
