A Cheap & Useful Cutting Table
41,791
61
35
About: I am leaving Instructables, soon. I am very upset with the turnaround that has the page to post the manufacture of a dildo. Me llamo Osvaldo Julio Schiavoni I speak Spanish, not English. I use automatic tr...
I make this cutting table 3 years ago, and I was made many things with it.
Step 1: Any Short Explanation
The pictures are of the first version. Later I took the angle grinder to the center of the table, screwing it to a board of iron of 1/8 inch so that the sharp disk stood out more than 1/2 inch.
The angle grinder is "removes and put", that is to say that I put it when I need to cut something, and then I remove it.
The angle grinder is very very cheap, but amazingly it has lasted many time, almost ten years.
The table is collapsible and was made of a little hard wood, red eucalyptus. It tolerates the bleakness without treatment.
Once again, you forgive my English.
Step 2: An Improvement
Any weeks after this instructable I did it an improvement: I carried the grinder support toward the center of the table.
As the wood is something thick (1 inch), I did a hole in it and I put in that place an iron plate of 1/8 inch, screwed with various screws, to which I fixed the grinder each time that I am going to use it. Of that way, the cutting blade exceed almost 20 mm.
Sorry the burry pictures.
You can see that the surface of the table has been attacked for the elements, but is not such badly considering that has been more than 5 years under the rain and the sun. I think that will lasts other 10 or more years.
Step 3: A New Enhancement (july 14, 2009)
Some months ago I buyed a electric welder. Then, I thought the attaching method deserves be reinforced.
Don't look the aesthetics of the weldings, it is horrible, but perform their function.
Today the grinder is much more firmly attached to the cutting table.
  • Paper Contest
    Paper Contest
  • Trash to Treasure
    Trash to Treasure
  • Organization Contest
35 Discussions
I_StarkGuy
5 years ago on Introduction
Muy buena idea, aquí en México la herramienta es ridículamente cara y decidí comprar un esmeril (amoladora creo que le llaman allá) y montarlo de distintas formas para obtener otras herramientas. Creo que usaré esto.
rimar2000I_StarkGuy
Reply 5 years ago on Introduction
Me alegro de haberte dado una buena idea. Pero fíjate que últimamente le he hecho algunas mejoras: llevar la amoladora al centro de la mesa, mejorar la sujeción, hacerla inclinable, hacerle una guía fácil de desplazar paralela, y al trineo hacerlo articulado para poder hacer cortes inclinados horizontalmente. Necesité hacer esos cambios porque como la había hecho al principio era muy limitada. Como está ahora me permite cortar hasta una pulgada, lo cual no es mucho pero para mí es suficiente.
Gracias por comentar.
faacuunndoo
6 years ago on Step 3
Che muy bueno, yo pensaba construirme una sierra así pero no sabía como agarrar la amoladora a la mesa, muy bueno. Yo me hice un soporte para que sea tipo ingleteadora y cambiando el disco sensitiva. Un saludo!
rimar2000faacuunndoo
Reply 6 years ago on Step 3
Ahora estoy planeando hacerme una radial, como la que tiene Phil B, porque él está muy satisfecho con la versatilidad que tiene. A esta que tengo pensé ponerle una bisagra que permita bajarla y subirla, pero siempre estoy limitado por el grosor de la chapa soporte.
Machine
6 years ago on Introduction
Nice.
It is simple, looks effective and isn't expensive (why spend money when you don't need to. Keep your money in your pocket where it belongs).
Saw blades are easily changed too.
But, I think the edge of the table might need a cover so that fingers or loose clothing don't have a chance to get near the blade.
rimar2000Machine
Reply 6 years ago on Introduction
Maybe you look the first photo. Today the cutting blade is in middle of the table, it is safer. I cut iron sheet in it, too.
Maybe I will make some adjustements, such add a lever to raise/lower the blade. At present I do this, when needed, adding timbers to raise the piece to cut.
Thanks for comment!
Phil B
8 years ago on Introduction
I do nto know how I missed this. I like it very much. It is very clever, and I am certain it is very useful to you.
rimar2000Phil B
Yes, I use it often. The grinder is one these cheap and bad quality, and I am waiting if burns to change it. Meanwhile, it seems persevere...
rimar20002 stroke
It depends only on the grinder you use. I never did it, but yesterday I cut 2mm steel plate, without problem. I did a 18x18cm lid for a pool drainage.
Phil Brimar2000
That is like my circular handsaw. I had a very good one. When I bought the radial arm saw my wife said, "You are not going to have two saws!" and she made me sell the good circular saw. A few years later I needed a circular saw and her parents gave me one as a gift that I never would have bought for myself. For 36 years I have been waiting for it to burn up so I could replace it with a better one, but it continues to work. Now I am old enough that I will not use a circular saw enough to make a new one worthwhile, even if the one I do not really like would burn up.
rimar2000Phil B
HAHAHA!!!
Well, then we can go to the bar and get drunk together and mourn our sorrows!
Phil Brimar2000
That may be a good plan. A comedian in the USA says women resent it when men go into the forest by themselves; but all they want to do is drink some beer, complain about women, and relieve themselves against a tree.
rimar2000dadu2007
Very clever!
I didn't think this, but my cutting table can do it! Thanks for the idea.
