A Different Design of "helping Hands"
Introduction: A Different Design of "helping Hands"
About: well im a strange one , ill admit that otherwise im kinda normal
This is my design of the seemingly popular "helping hands". My design is very simple to buld also.
Teacher Notes
Step 1: Tools Needed for the Construction
The supplies include:
1 small piece of plexiglass or wood to use as the base
wire easily bendable yet firm
2 small screws with large heads
1 1" bolt wiht washer and nut
2 clothespins,aligator clips ect
2 drill dits 1 to use to drill pilot holes for the 2 screws mentioned above, the other 1 size larger than the bolt mentioned above
a countersink
a power drill
needle nose pliers
and a bit to drive the 2 large-headed screws
patience
Step 2: Drill Holes in the Base
Simply put, drill the large hole (i forgot to measure how big it was, i eyeballed it) and counter sink 1 side, the side you countersinked will be the bottom.
Step 3: Now Bend the Wires to Have Eyelets on Both Ends
Use the needle nose pliers to bend a loop, also known as an eyelet ao attach the base to your aligator clips, in my case none were available, so i used clothespins.
Step 4: Now Attach the Clips/clothespins
now take your clothespins and drill a pilot hole for the 2 large-headed screws(for i dont have their actual name, this will suffice)and drive 1 screw through the loop in the wire into the clothespin. repeat this step witht he second side. if you are using aligator clips you could just solder to the wire, but make sure to insulate between teh 2 wires in the next step.
By the way my camear is really cheep $59.99 and 3.2 MP from newegg.com and decides when it wants to take good and bad pics, this is obviously not good at all.
Step 5: Attach the Wires to the Base
attach the wire/clothspin on the opposite end of the clothespin to your base( the 2nd loop u made
Step 6: Attach the Wires to Your Base
Again you are definatly not limited to plexiglass i chose it, along with this entire project because i had al of these supplies an my disposal and i liked the concept. Anyways now attach the unused end of the wire to your base.
Step 7: Now You Should Be Done
Now enjoy using your newly created simple helping hands. This pic isnt very clear but i was soldering 2 wires onto 2 terminals of and on off switch for use in anothe project.
I would like to make it known that i am in fact a noob at posting on instructables, although i have looked at many instuctables and enjoy reading them.
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    11 Discussions
    jay-mann--
    jay-mann--
    11 years ago on Step 4
    hey umm just wonderin what do these helpin hands actually do???
    cross99
    cross99
    Reply 10 years ago on Step 4
    lol, a helping hand is used in electronics to hold projects while soldering to them, example: you use it to hold a PCB (Printed Circuit Board) while you solder the wire to it or any other project you are soldering, you just use the helping hands to hold it so basically, thats what a helping hand do ;-)
    mjones
    mjones
    10 years ago on Introduction
    cut the ends of the clothes pins flat, they are much more useful that way
    !Andrew_Modder!
    !Andrew_Modder!
    12 years ago
    ehh... nice post but Iv seen better (bottom weight not very heavy, and Clothspins!!?!?.)
    maker-x
    maker-x
    13 years ago
    the pics are just rubbish!
    VIRON
    VIRON
    13 years ago
    Reminds me of the time I screwed down a sponge and a coiled up coat hanger to make a soldering station for a $5 soldering iron. (Nostalgia)
    frank113
    frank113
    13 years ago
    well Junkyard John, i was reffering to soldering the aligator clips i didnt have at the time, that being the case i substituted clothespins
    Junkyard John
    Junkyard John
    13 years ago
    Soldering iron plus wood equals burn equals getting charcoal all over your soldering project.
    Junkyard John
    Junkyard John
    Reply 13 years ago
    At least thats how I picture it. I'm probably wrong.
    VelvetElvis
    VelvetElvis
    13 years ago
    Elegant in its simplicity. Solid copper house wire would work well with this (probably 10 ga. or 8 ga.)
    westfw
    westfw
    13 years ago
    I used a random steel case as a base, and mounted clips on magnets. You can see it here: http://www.geocities.com/westfw/finjig/finjiga.html (probably does't rate yet another instructable.) Mine was aimed at model rocket construction, but there's no reason it couldn't be used for other things.
