Airsoft BB Holder With a Film Canister
3,564
9
16
A airsoft BB loader that holds 150+ BBs out of a film canister.
Step 1: Get the Materials
Materials
-One pen
-One empty film canister
-One bottle eraser
-Scissors
Step 2: Make the Ammo Holder
Cut a small hole in the film canister cap with the scissors. Widen the hole to be a little less wide than the tube you are putting in.
Step 3: Make the Loading Tube
Next, disassemble the pen and either use the grip, or the container. I prefer the grip because it's flexible and easy to work with. Make sure it is wide enough so a BB can EASILY slide through. If it isn't, you will have trouble pouring the BB's out.
Step 4: Completing the Design
Slide the loading tube into the film canister, about halfway, and fill the canister about 3/4 of the way full with BB's. Now you have your own , hopefully working loader for under $1. Mess with it to get the loading speed just right. It holds 100+ BB's, so you probably won't run out. Hey, if you do, make 10 of them.
Step 5: Using the Loader
Once completed, you will want to plug the loader during use so the BB's don't fall all over the ground. Use the bottle eraser, when needed, and gently ease it into the loading tube, until the "neck" of the eraser is no longer visible. Now go out and airsoft!!!
      • Planter Challenge
        Planter Challenge
      • Barbecue Challenge
        Barbecue Challenge
      • Backyard Contest
        Backyard Contest
      16 Discussions
      :-P, ok then. the same bottle at 'destany merchant' near me, for 10$ lol. (i mean hey, come on.yeah come on, you no you want to.)
      codongolev
      11 years ago on Introduction
      look at the one with the party popper. short, simple, and easy.
      GorillazMiko
      Wow, great idea, looks really small and easy to do. I will probably show my friend this, this is a really good idea. (added to favorites)
      jonathan111
      thank you! its not a speed loader of course, but for a pistol, its very light, small, and easy.
      tjsdaname
      nice Instructable! this would be good when your out on the field because it is small and light
      X_D_3_M_1
      Spead loader? I thought u meant the ones u pump, for spring loaded mags. this is stupid other wise
      marc92
      nice instructable, but the pictures are lacking quality.
