AC/DC Clock
Introduction: AC/DC Clock
About: 3rd year Mechanical Engineering student. Maker when possible and DIY culture lover. If something explodes, revise the diagrams! Check the "to be written" projects here! www.instagram.com/elbauldelma…
How to make an easy and cheap clock at home!
Step 1: Getting Inspired
As an AC/DC fan I have a big wall poster. For ages I had been thinking about making my own clock but I didn´t find something cool to do... until I looked at the wall.
A new idea had appeared!
Step 2: Materials Needed
  • White glue.
  • Coping saw.
  • Sand papers.
  • 5mm plywood panel.
  • Quartz clock with hands.
  • Red and black spray paint.
  • Inkjet with white and photographic paper sheets.
Step 3: Printing the Model
  • Choose a base image for your clock. In my case, I´m using the Black Ice album Angus Young silhouette.
  • Resize the image as you wish and print it on a white paper sheet . This model has a 20cm diameter
Tip: Look for easy-to-cut images. Inner gaps may be difficult to remove!
  • Cut the prints trying to keep as many thick surfaces as possible, otherwise the pieces might break down while using the saw.
  • Fix the prints to the wood panel using cellophane tape. With a pencil draw the contour of the pieces on it.
Tip: Notice that the guitar has two strange extensions on the neck. They offer extra support for the word D.
Step 4: Cutting the Pieces
  • Remove the papers from the plywood and cut the pieces with a coping saw. Follow the pencil lines you have done previously.
Tip: Empty the inner holes first. Later will be difficult!
Step 5: Adding the Mechanism
Cheap clock mechanisms can be easily found on Internet. I bought a Quartz clock with hands on eBay for 1€!
Okay. They are not very reliable and the battery doesn´t last long but for simple DIY projects are perfect.
This model comes with a washer and nut. Not complex linkers or glue are needed, just drill the piece where you want to fit the clock´s hands.
Step 6: Sanding and Painting
  • After cutting and drilling the pieces some splinters may have appeared.
  • Remove them using sand paper, scrub the surface till it is smooth and uniform.
  • The pieces are now ready. Put them on a plastic surface and apply the spray paint.
Don´t forget cleaning the dust with cloths before painting!
Tip: For high quality results, primer should be applied before painting.
Step 7: Creating the Background
Without a background you can see the wall behind the clock and the mechanisms. It doesn´t look cool.
We can improve our model adding a printed image on photographic paper. Flames seem appropriate for a rock band.
  • Adjust the sheet shape to the circle´s contour. Cut it few millimetres smaller than the circle itself.
  • While in position. Add white glue on the paper edges and spread it until it reaches the wooden parts.
Step 8: Everything in Its Right Place
  • Glue the words carefully.
  • Attach the mechanism to the base. Add some glue on the lightning and fix it too.
  • Install the washer and tighten the nut. Finally, put the hands in their positions.
Our custom-made clock is now finished!
Be the First to Share
    • Mason Jar Speed Challenge
    • Pumpkin Challenge
      Pumpkin Challenge
    • Bikes Challenge
      Bikes Challenge
    4 Discussions
    JohnSmith-Workshop
    JohnSmith-Workshop
    2 years ago
    Awesome job mate, love the design. A prefect gift for a friend :D
    Kozmicblues69
    Kozmicblues69
    2 years ago
    Oh yeah! I love it! The result is very cool. Great job!
    tomatoskins
    tomatoskins
    2 years ago
    This is awesome! I love the finished look of the clock!
    Francisco Moliner
    Francisco Moliner
    Reply 2 years ago
    Thank you!
    This is one of the first projects I made years ago. Improved and better explained models will be shared soon!
