Adding Parts Cooling Fan to Your 3D Printer
8,101
13
About: Avid 3D printer builder, currently completing my 3rd printer design. If you like what you see and maybe even implement what provide, consider supporting me on Patreon.com: https://www.patreon.com/Core3d_tech...
For those of you new to 3D printing, most 3D printer do not come with a cooling fan. Yes there's a fan right on the extruder (and it may very well be the loudest part to your printer) but that fan only cools the Hot-end Heat sink. It prevents heat from traveling up to the extruder, which can cause all sorts of issues.
The Cooling fan we're talking about here is to cool the filament that is deposited on your print. Cooling your print can make the difference between a beautiful print and a failed print.
The parts cooling fan is controlled independently from the Hot-end fan (which generally, is always on). Most slicers will automatically insert all the right g-code to run the parts cooling fan in the right places and at the right time.
Btw, some materials should not not be cooled AT ALL so don't fall for the "cooling extruder and filament simulaniously". That can't be good.
Step 1: Connecting the Cooling Fan
This is assuming you are using a RAMP 1.4 and Marlin 1.1.x, although similar principals apply to other boards. On the RAMPS Shield there are 3 power outlets that can be configured for different functions. These are D8, D9 and D10 (blue connectors).
Generally D8 is reserved for heating the bed and D10 is reserved for Extruder 0 (the first extuder). D9 can be assigned to either a second Extruder or to a cooling fan.
In this case we'll be attaching the cooling fan to D9 (polarity matters so make sure the plus aligns with the fan's red wire).
Step 2: Setting Up Marlin 1.1.x With Cooling Fan
This is just a matter of selecting the proper board configuration. In your marlin code base you'll find a file called boards.h. In it you'll find all the boards currently supported by marlin and for each board there are different options.
#define BOARD_RAMPS_OLD         3     // MEGA/RAMPS up to 1.2
#define BOARD_RAMPS_13_EFB 33 // RAMPS 1.3 (Power outputs: Hotend, Fan, Bed) #define BOARD_RAMPS_13_EEB 34 // RAMPS 1.3 (Power outputs: Hotend0, Hotend1, Bed) #define BOARD_RAMPS_13_EFF 35 // RAMPS 1.3 (Power outputs: Hotend, Fan0, Fan1) #define BOARD_RAMPS_13_EEF 36 // RAMPS 1.3 (Power outputs: Hotend0, Hotend1, Fan) #define BOARD_RAMPS_13_SF 38 // RAMPS 1.3 (Power outputs: Spindle, Controller Fan)
#define BOARD_RAMPS_14_EFB 43 // RAMPS 1.4 (Power outputs: Hotend, Fan, Bed) #define BOARD_RAMPS_14_EEB 44 // RAMPS 1.4 (Power outputs: Hotend0, Hotend1, Bed) #define BOARD_RAMPS_14_EFF 45 // RAMPS 1.4 (Power outputs: Hotend, Fan0, Fan1) #define BOARD_RAMPS_14_EEF 46 // RAMPS 1.4 (Power outputs: Hotend0, Hotend1, Fan) #define BOARD_RAMPS_14_SF 48 // RAMPS 1.4 (Power outputs: Spindle, Controller Fan)
#define BOARD_RAMPS_PLUS_EFB 143 // RAMPS Plus 3DYMY (Power outputs: Hotend, Fan, Bed) #define BOARD_RAMPS_PLUS_EEB 144 // RAMPS Plus 3DYMY (Power outputs: Hotend0, Hotend1, Bed) #define BOARD_RAMPS_PLUS_EFF 145 // RAMPS Plus 3DYMY (Power outputs: Hotend, Fan0, Fan1) #define BOARD_RAMPS_PLUS_EEF 146 // RAMPS Plus 3DYMY (Power outputs: Hotend0, Hotend1, Fan) #define BOARD_RAMPS_PLUS_SF 148 // RAMPS Plus 3DYMY (Power outputs: Spindle, Controller Fan)
In case of the RAMPS 1.4 (BOARD_RAMPS_14_XXX) you can select the different configuration of the power outputs.
In the case of my printer I happen to have 1 extruder, 1 heated bed and one cooling fan so BOARD_RAMPS_14_EFB (43) it is.
This means that in the configuration.h you set the board to this one:
// The following define selects which electronics board you have.
// Please choose the name from boards.h that matches your setup #ifndef MOTHERBOARD #define MOTHERBOARD BOARD_RAMPS_14_EFB #endif
This is all you need to do with regards to the cooling fan installation in the software. The rest of the cooling fan settings is controlled by the g-code
Step 3: Testing Your Fan and Setting Up Your Slicer
You can test your cooling fan by directly sending it g-code to control the fan. In software like Pronterface or through an interface like Octo Print's you can send the command M106 S[0.255] (M107 turns it off).
The slicer software is what will generate the g-code and it will have a section for setting up your cooling fan configurations. More slicer software applies some intelligence to how and when to apply cooling.
In Slic3r the cooling setting are associated with the Filament setting (as they differ per type of filament).
In cura 1.7.0 you'll find a cooling section under the Print Setup.
I think that covers how to get started with adding a cooling fan on your 3D printer. Good luck figuring out the best setting for each material you choose to print with (remember some like ABS can't handle cooling at all).
If you liked this check out my other instructables or visit my website at https://core3d.tech
Epilog Challenge 9
Epilog Challenge 9
    • Backyard Contest
      Backyard Contest
    • DIY Summer Camp Contest
    • Paint Challenge
      Paint Challenge
    3 Discussions
    ianmcmill
    Question 6 months ago
    It's not clear to me how you control the hotend fan and the parts cooling fan.
    Are they controlled separately? Or do they spin up at the same time?
    You connect the print/part cooling fan to D9. But where do you connect the hotend fan to?
    D8 is for heat bed and D10 is for the extruder heater.
    From what I understand is that your setup replaces the hotend fan with the parts cooling fan?
    I am confused.
    Core3Dianmcmill
    Answer 6 months ago
    My apologies, since this was about adding the parts cooling fan and since every printer should already have a hot-end fan I didn't go into where the Hot-end fan goes. In most printers the Hot-end Fan is always on.
    For a RAMPS board that means it's connected to the two pins in the yellow circle. The parts cooling fan is connected to the remaining D9
    ianmcmillianmcmill
    Answer 6 months ago
    Wait!
    There is this small pin left of the X axis stepper slot which controls the hotend cooling fan!
