Adjustable Angle Handle for Cutlery
Introduction: Adjustable Angle Handle for Cutlery
This handle is for
people with difficulty in grasping cutlery. It is designed to easily put and remove spoons or forks, just loosening and tightening a screw. In addition, it has all the empty handle so that weight is added in case the person has tremors that hinder the activity of eating.
It has been designed for use in pediatrics. it is difficult to find cutlery adapted to the size of a child's hand.
--------------------------------Spanish----------------------------------------
Este mango es para personas con dificultad en el agarre de cubiertos. Está diseñado para poder poner y quitar fácilmente cucharas o tenedores, solo aflojando y apretando un tornillo. Además, dispone de todo el mango vacío para que se añada peso en el caso de que la persona tenga temblores que dificulten la actividad de comer.
Se ha diseñado para su uso en pediatría. Es difícil encontrar cubiertos adaptados del tamaño de la mano de un niño
Supplies:
Filament for 3D PLA or PET printer
· 1 M4 nut
· 1 M4 Self-locking nut
· 1 Screw 4x35mm
· 1 4x15mm screw or 4x15mm thumbscrew
· 1 10x100mm screw or 1 10x15mm screw and weights of different sizes: rice, sand, stones, etc.
· Filamento para impresora 3D PLA o PET
· 1 Tuerca M4
· 1 Tuerca M4 Autoblocante
· 1 Tornillo 4x35mm
· 1 Tornillo 4x15mm o palometa 4x15mm
· 1 Tornillo 10x100mm o 1 tornillo 10x15mm y pesos de distintos tamaños: arroz, aren
Teacher Notes
Step 1: Prepare for 3D Printing
Printer settings:
· Resolution: 0.20mm
· Infill: 40%
· Perimeters: 3
· Support: Yes
· Raft: No
Parámetros impresora:
· Resolución: 0.20mm
· Relleno: 40%
· Perímetros: 3
· Soportes: Si
· Raft: No
Step 2: Assembly
1. Clean parts supports
2. Insert M4 nut in the printed part "Adaptador cubierto"
3. Put M4x15mm screw or pin in the printed part "Adaptador cubierto"
4. Join the two printed parts with the M4x35mm screw and the self-locking M4 nut
5. Put the M10x100mm screw to add weight or weights of different sizes. (You can also cut the M10x100 screw and combine it with weights of different sizes)
1. Limpiar soportes de las piezas
2. Introducir tuerca M4 en la pieza impresa "Adaptador cubierto"
3. Poner tornillo o palometa M4x15mm en la pieza impresa "Adaptador cubierto"
4. Unir las dos piezas impresas con el tornillo M4x35mm y la tuerca M4 autoblocante
5. Poner el tornillo M10x100mm para añadir peso o los pesos de distintas medidas. (También se puede cortar el tornillo M10x100 y combinarlo con pesos de distinto tamaño)
Assistive Tech Contest
Be the First to Share
    • Trash to Treasure Contest
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    audreyobscura
    audreyobscura
    8 weeks ago
    Clever design - thanks for including your file too!
