All Year Round Greetings
Introduction: All Year Round Greetings
All Year Round Greetings, a blessing gift which fits for all ages!
All Year Round Greetings is designed for Arduino beginners to construct.
Supplies:
1. Styrofoam board x 1 (width: 28 cm length: 15 cm )
2. Four photos of four seasons
3. Small embellishment (optional)
4. One large round box (height: 10 cm and diameter: 22cm)
5. One cover (diameter: 22.5 cm)
6. Stepper Motor x1
7. Small greeting card x1
8. Utility knife x1
9. Cutting board x1
10. Pencil x1
11. Cardboard x1 (if it is bigger than the area of 11cm x 11 cm then it's ok)
12. Hot glue x1
13. Double-sided tape x1
14. Arduino wires
15. Arduino board
16. Wire that connects the computer
Step 1: Coding and Arduino Electrical Diagram
Coding link:
https://create.arduino.cc/editor/Amanda930614/fcdf...
Translation of the coding (Into English)
Green - Control (program)
Red - Adafruit
Light Yellow - Digital Pins
Step 2: Making the Basic Structures
Prepare a styrofoam board, cut it into four even 7 cm by 15 cm pieces (width x length)
After that, use the remaining styrofoam board to make the bottom plate. Cut out a circle from the styrofoam with a diameter of 14 cm, and stick it with a black paper that has an exact size with it.
Step 3: Adding Pictures
Print out 4 different seasonal pictures and trim them into the size that is same as the styrofoam board with the width of 7cm and the length of 15cm. Stick all of the 4 pictures on the 4 styrofoam boards respectively.
Step 4: Decorating
Glue all four styrofoam boards with pictures on the bottom plate, and decorate the empty spaces with embellishments accordingly. After completion, glue the bottom plate onto another piece of cardboard, which has a diameter of 11 cm by using double-sided tape.
Step 5: Making the Base
Use the remaining cardboard to make a round plate that has a diameter of 22.5 cm. Cover the 22.5cm diameter plate onto a rounded box (height: 10 cm and diameter: 22cm.) Cut a small hole on the edge of the 22.5 cm plate in order to let the wire that is connected to the computer and all the arduino wires out.
Step 6: Fine-tune the "All Year Round Greetings"
Use the cover to hide all the wires, Arduino board and inside the box. Stick the stepper motor at the bottom of the small cardborad plate, and put the entire decoration onto the cover. In order to let the stepper motor function smoothly, you could stick two lids on the cover of the box.
Step 7: Final Touch : Greeting Card
Write a small greeting card, then stick it on the 22.5 cm plate. Finally, add decorations (optional).
Step 8: Completion!!
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
