Alternative Heating Controll Circuit
Introduction: Alternative Heating Controll Circuit
When we use heating circuit in class, we choose the most productive way to make it. In our Computational Craft class, we use copper tape to build the circuit.
However, in our soft circuit making process, sometimes we may need to change the circuit to looks like our craft theme.
In the instructable, I will show you how to build the alternative heating controll circuit.
Supplies:
Felt fabric, copper thread, needles, FQP30N06L, arduino, connection wires.
Teacher Notes
Step 1: Plan for the Circuit
The original circuit and the alternative circuit I imagined.
Remember to abstract all the lines.
Step 2: Make the Felt Leaves
First, draw the outline of the leaves.
Then use transfer paper to draw it on felt fabric.
Then cut them off along the line.
Step 3: Use Thread to Sew and Embroidery
Use copper thread as conductive circuit to sew and embroidery the circuit on leaves and fabric. Remember to look at the circuit we imagined in step 1.
Remember to leave enough length of thread at the end, so it can connect with other circuit easily.
Step 4: Solder All the Electronics
Place the FQP30N06L, 100k Ohm resistor, and 1N4001 Diode to the place in the image.
Then solder them with the particular copper thread.
Step 5: Connect the Finished Heating Control Circuit With Arduino!
arduino code:
void setup() {
// put your setup code here, to run once:
pinMode(9, OUTPUT);
void loop() { // put your main code here, to run repeatedly:
analogWrite(9, 130);
delay(500);
// analogWrite(9, 0); // delay(1000);
And see if its working!
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
