Alternative to the Broken IKEA Vidga Curtain Rail Connector
Introduction: Alternative to the Broken IKEA Vidga Curtain Rail Connector
Accidentally break the plastic IKEA Vidga curtain rail connector? Here is a cheaper and durable (metal) alternative solution.
Materials:
1. Bolt, M6 x 12mm
2. M6 nut
3. M6 washer x 2
Tools:
1. Flat steel file
2. 10mm spanner
3. Plyer
Teacher Notes
Step 1: Prepare the Washers
The M6 washer outer diameter is slightly larger than the size of Vidga curtain rail slot.
File the washers to shape it to fit into the 12mm slot.
Step 2: Assembly
Put all together as shown in photo. Tighten the bolt and nut.
Try a shorter bolt if extrude is too obvious.
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
