Ambient Real Time Clock
Aim
I made this Clock because I have a addressable LED strip laying around and I want to use it. Then I saw my room doesn't have a good Clock that matches its walls. So I Decided to make a Clock which can change its colors according to users mood or wall color.
Teacher Notes
Step 1: YouTube Video
Watch this youtube video for full instructions
Step 2: Procedure
I firstly took a 24 x 15 inch plywood board.
Cut LED strip into pieces and paste them on the board Then After soldering them I cover the whole with a black chart paper Then paste a thermocoal sheet on top of it and cut the thermocoal with a sharp cutter in shape of 4 seven segment displays along with two holes in center. Then made my circuit ready using circuits diagram given below
and pasted this all behind the board. I also ordered a custom pcb for the same from https://jlcpcb.com they provide best pcb prototypes for lowest price from china and ship worldwide fast and secure. after soldering all my components on my board I removed the breadboard and fixed everything behind the board and covered front section using a thin translucent trace paper. The clock looks awesome and increase the beauty of wall. customization colors make it perfect for any wall.
If you like this project kindly Subscribe on youtube or visit our website http://robocircuits.com Thank you for reading!
Step 3: Code
/* The Code is Designed by RoboCircuits
* Visit our Website http://robocircuits.com for assistance on this code * This code uses DS3231.h Library download it from http://robocircuits.com * For Full Tutorial Watch video on our YouTube Channel https://youtube.com/robocircuits */
#include #include
int i=0,j=0,k=150;
// Init the DS3231 using the hardware interface DS3231 rtc(SDA, SCL);
#ifdef __AVR__ #include #endif
// Which pin on the Arduino is connected to the NeoPixels? // On a Trinket or Gemma we suggest changing this to 1 #define PIN 6
// How many NeoPixels are attached to the Arduino? #define NUMPIXELS 45
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals. // Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest // example for more information on possible values. Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 500; // delay for half a second
void setup() { // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket #if defined (__AVR_ATtiny85__) if (F_CPU == 16000000) clock_prescale_set(clock_div_1); #endif // End of trinket special code
pixels.begin(); // This initializes the NeoPixel library. // Setup Serial connection Serial.begin(115200); // Initialize the rtc object rtc.begin(); // The following lines can be uncommented to set the date and time //rtc.setDOW(WEDNESDAY); // Set Day-of-Week to SUNDAY //rtc.setTime(12, 0, 0); // Set the time to 12:00:00 (24hr format) //rtc.setDate(1, 1, 2014); // Set the date to January 1st, 2014 }
void loop() { if(digitalRead(2)==HIGH) { int a= analogRead(A0); int b= analogRead(A1); int c= analogRead(A2); i=map(a,0,1025,0,150); // Green Color j=map(b,0,1025,0,150); // Blue Color k=map(c,0,1025,0,150); // Red Color } else { i= 0; j= 0; k= 150; }
// Code for Backlight for(int x=29;x<=45;x++) { pixels.setPixelColor(x, pixels.Color(i,j,k)); pixels.show(); }
// Fetching Real Time from rtc String x=rtc.getTimeStr(); // Send time Serial.println(rtc.getTimeStr()); int hour1= x.charAt(0); int hour2= x.charAt(1); int min1= x.charAt(3); int min2= x.charAt(4); hour1=hour1-48; hour2=hour2-48; min1=min1-48; min2=min2-48;
// Displaying time on Clock switch(hour1) { //case 0 : zero(0); //break; case 1 : one(0); break; case 2 : two(0); break; default : nulll(0); break; } switch(hour2) { case 0 : zero(7); break; case 1 : one(7); break; case 2 : two(7); break; case 3 : three(7); break; case 4 : four(7); break; case 5 : five(7); break; case 6 : six(7); break; case 7 : seven(7); break; case 8 : eight(7); break; case 9 : nine(7); break; default : nulll(7); break; } switch(min1) { case 0 : zero(15); break; case 1 : one(15); break; case 2 : two(15); break; case 3 : three(15); break; case 4 : four(15); break; case 5 : five(15); break; default : nulll(15); break; } switch(min2) { case 0 : zero(22); break; case 1 : one(22); break; case 2 : two(22); break; case 3 : three(22); break; case 4 : four(22); break; case 5 : five(22); break; case 6 : six(22); break; case 7 : seven(22); break; case 8 : eight(22); break; case 9 : nine(22); break; default : nulll(22); break; } pixels.setPixelColor(14, pixels.Color(i,j,k)); pixels.show(); delay(250); pixels.setPixelColor(14, pixels.Color(0,0,0)); pixels.show(); delay(250); }
void zero(int a) { pixels.setPixelColor(a+0, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+1, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+2, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+3, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+4, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+5, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+6, pixels.Color(i,j,k)); pixels.show(); } void one(int a) { pixels.setPixelColor(a+0, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+1, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+2, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+3, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+4, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+5, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+6, pixels.Color(i,j,k)); pixels.show(); } void two(int a) { pixels.setPixelColor(a+0, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+1, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+2, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+3, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+4, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+5, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+6, pixels.Color(0,0,0)); pixels.show(); } void three(int a) { pixels.setPixelColor(a+0, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+1, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+2, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+3, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+4, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+5, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+6, pixels.Color(i,j,k)); pixels.show(); } void four(int a) { pixels.setPixelColor(a+0, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+1, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+2, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+3, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+4, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+5, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+6, pixels.Color(i,j,k)); pixels.show(); } void five(int a) { pixels.setPixelColor(a+0, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+1, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+2, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+3, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+4, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+5, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+6, pixels.Color(i,j,k)); pixels.show(); } void six(int a) { pixels.setPixelColor(a+0, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+1, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+2, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+3, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+4, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+5, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+6, pixels.Color(i,j,k)); pixels.show(); } void seven(int a) { pixels.setPixelColor(a+0, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+1, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+2, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+3, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+4, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+5, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+6, pixels.Color(i,j,k)); pixels.show(); } void eight(int a) { pixels.setPixelColor(a+0, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+1, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+2, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+3, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+4, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+5, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+6, pixels.Color(i,j,k)); pixels.show(); } void nine(int a) { pixels.setPixelColor(a+0, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+1, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+2, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+3, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+4, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+5, pixels.Color(i,j,k)); pixels.show(); pixels.setPixelColor(a+6, pixels.Color(i,j,k)); pixels.show(); } void nulll(int a) { pixels.setPixelColor(a+0, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+1, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+2, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+3, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+4, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+5, pixels.Color(0,0,0)); pixels.show(); pixels.setPixelColor(a+6, pixels.Color(0,0,0)); pixels.show(); }
Step 4: ThankYou
visit http://robocircuits.com
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
