Introduction: An Elegant Inverted Ponytail
Ever feel like you need a little more variety to your hairstyles? Miss Sarcastic and bookworm11 have come together to create a sizzling style for an awesome summer.
Step 1: Pull Back Your Hair
The first step to the inverted ponytail is to put your hair in a ponytail. This ponytail should be low and rest at the nape of your neck.
Step 2: Divide and Conquer
Part your hair just above the hair tie. If your hair is short be careful not to separate your hair too much, or it will fall out of your hair tie in the next step.
Step 3: Flip Inward
For the final step, grab the ponytail through the part and pull through. You may tighten your ponytail if it has become loose.
Step 4: Pin and Accessorize
Use bobby pins to hold your hair in place. You may add flowers, ribbons or other accessories to adjust the inverted ponytail to your taste.
Hair & Makeup Contest
