Analogic Drawing Pad
212
5
Introduction: Analogic Drawing Pad
About: Ngo active in the field of digital mediation, based in Toulouse, France
In this tutorial you will learn how to create your own analogic drawing pad, something along the lines of an Etch a Sketch board.
Teacher Notes
Step 1: Parts
10x M4x25mm screws
34x M4 Nuts
2x big pulleys
8 x small pulleys
1x A4 size MDF board, 3mm thick
2x long wooden skewers
nylon wire
Step 2: Draw the Different Parts of the Pad on the Wooden Board
You will need to draw 10 pulleys in total. To draw the pulleys, just place them on the board and draw their contour.
Place de pulleys marked with “1” at 2cm from the sides of the board, and 5cm from the bottom of the board (the bottom of the board is the longest side).
Step 3: Lock the Pulleys to the Board, Using Screws and Bolts and Washers
Use 3 bolts in total for the small pulleys (the blue ones) and 5 bolts plus 2 washers for the big pulleys (the control pulleys -in red)
Step 4: Wrap the Nylon Wire Around the Blue Pulleys and the Control Pulleys
Watch this video to learn how
You can also watch this video if you struggle with the wiring.
Use a piece of cardboard to place two wooden skewers at 90° angles with respect to one another.
The skewers need to be long enough to reach the nylon wire on the top bottom left and right of the pad.
Step 5: Use Some Hot Glue to Stick the Ends of the Skewers to the Nylon Wire
If you’ve assembled all parts in the correct way, both skewers should be able to move freely around the pad (along the x and y axis of the pad).
Step 6: Create the Support for the Pen
We now need to create a support for the pen. Use a piece of cardboard to create it, then glue it to the other piece of cardboard hosting the skewers.
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
