Introduction: Android Auto Portable Dev-Box (DIY)
Overview
The Android Auto portable head unit (HU) is a do-it-yourself project for developers wanting to test and demonstrate their Android Auto application outside of an in-vehicle implementation. Assembling the portable HU involves modifying a standard toolbox to house an Android Auto-capable head unit:
Hardware
  • 26” Toolbox
  • Box Divider - 2 layer acrylic plexiglass (refer to divider specs)
  • Android Auto Unit - Includes Mic, USB extender and wiring adapter
  • AC/DC Converter - US only 110v to 12VDC @ 5.8 Amp
  • Speakers - (2 speakers, 1 pair) 5.25” or 4" depending on preference
  • Screws + Nuts - (30 needed) 10-32 x 0.5"
  • L-Brackets - (4 needed) 2.5” x ⅝”, for mounting head unit to box divider
  • Hinges - (2 needed) 1.5” hinges
  • Switches - (2 needed)
Tools:
  • Double sided velcro tape (to secure AC/DC to toolbox)
  • Wire stripper
  • Drill with the following bits:
    • 3/16 bit for Screw ports
    • 11.5mm for Mic port
    • 11mm for Switch ports
  • Phillips #2 (star) screwdriver
  • Electrical tape and/or wire crimpers
Step 1: Box Divider Layout
Step 2: Wiring
Step 3: Assembly Tips
  • L-Brackets - screw brackets to closest opening holes to front display on headunit
  • AC/DC Converter - after cutting cig lighter adapter, wire with white text print is usually positive charge
    • please use region specific converter for countries outside US
    • another alternative would be to add a universal voltage adapter
  • Hinges - Align and install hinges with pivot divider midpoint to edge of toolbox opening
Step 4: Wrap-Up
  • given all hardware and tools are set to go, assembly and wiring should take around 2-3hrs
