Angry Iron Fist
2,779
9
4
Introduction: Angry Iron Fist
I am thinking about that in our daily life, when we encounter something that makes people angry, is there anything that can carry our anger and release the anger?
I made this demo which called angry iron fist. You only need to spend half an hour to make this glove like me. Believe me, it is definitely worth your time to make this!
With each quick fist-punch, the anger value will gradually be accumulated and there will be a sound effect of the fist. The higher the anger value, the faster the speed of the aura will be. When the anger value reaches the peak, waving the fist again will make an explosion sound.
Teacher Notes
Step 1: What We Need
Hardware
1 x Seeeduino nano
1 x Grove-Shield for Arduino Nano
1 x Grove-RGB LED Ring(20-WS2813 Mini)
1 x Grove-Mp3 V3 -Music Player
1 x micro SD Card
1 x speaker
1 x Grove - 6-Axis Accelerometer&Gyroscope
1 x Battery
Many grove cables
Structural
3mm thick acrylic board
1 x glove
some glue
some heat shrink tube
Tool
Hot melt glue gun.
Electric soldering
Iron laser cutter
Step 2: Draw and Design CAD
Here you can design drawings based on the actual size of your gloves, or you can use the CAD file I have created.
Step 3: Laser Cutting
Then we need to cut the the board by using laser cutting. If you don't have a laser cutting at home, you can find some in the hacker space near from you easily. If there's n o hacker space nearby, you can try the Laser Cutting Servicesupply by Seeed.
Step 4: Transfrom the Battery
Since our battery is two ports, in order to link to seeedunio nano easier, we need to make a small modification to transfrom the battery to Grove interface.
Firstly, we should cut the port of battery and the port of Grove line
Secondly, we use red wire to red wire and black wire to black wire to solder them
Step 5: Software Work
Step 6: ​ Hardware Connecting
Connect the hardware as shown below:
Step 7: Build Up
This work is actually being modified while trying many different solutions. Now this version is also a bit rough, and a more refined version will be produced in the future. I hope everyone will like it.
Wearables Contest
This is an entry in the
Wearables Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    4 Discussions
    genia19911
    genia19911
    3 days ago
    thanks nice and funny project :)
    linterislinter
    linterislinter
    Reply 2 days ago
    thank you and I hope you can keep to see my post
    jessyratfink
    jessyratfink
    13 days ago
    The sound effects are fun!
    linterislinter
    linterislinter
    Reply 9 days ago
    Thank you for loving my video
