Introduction: Animatronic Eyeball Monster
I started out with a eyeball hanging on my door. I wanted to continue the eyeball theme, and decided to make an animatronic eyeball monster. This monster would have a human body, but would have a giant eyeball as a head. It was pretty easy to make, and wasn't a big investment.
You're going to need some wood for the armature of the eyeball monster. I used scrap wood to make this, it could basically be made out of anything. To create the motion, I used a small oscillating fan. The eyeball would turn his eye from side to side. And you're also going to need something to dress you monster up with. I used some sheets.
Step 1: Build the Armature...
I built the armature of my Eyeball monster mostly out of scrap wood. When I ran out of wood, I used some PVC pipe. Building the whole thing out of wood or building the whole thing out of PVC really wouldn't make all that much of a difference.
How exactly you build it doesn't make all that much of a difference either. All of this will be covered up, so as long as the frame holds up, it will work. An important feature of my design is to put a flat piece of wood at the top of the frame, where the neck would appear to be. This is where the fan will go, so it should have a stable place to sit. Build your armature accordingly based on how your fan will fit into the frame.
I next added the fan to the frame. The fan should be resting on some stable surface. On my armature, it's a flat piece of wood. I secured the fan by taking 4 long wood screws and drilling them through the frame so they would come out just above the base of the fan, without going into the fan. This allowed the fan to be easily removed by unscrewing the screws, but it also kept the fan attached to the frame pretty well.
I based the armature off of the armature that I had already made for my Grim Reaper Animatronic, so the two are very similar.
Step 2: Make an Eyeball...
Follow the instructions here on how to make an eyeball. These are the instructions for my Eyeball Door Hanging. The eyeball that I used on this figure was of the same design.
Step 3: Dress Up Your Figure...
My eyeball animatronic has worn several different things over the years that I've had him. Normally, I just drape a sheet of fabric over him. His first costume was a blue sheet, but in the more recent Halloweens, this eyeball monster has worn a white cloak. Both of them look good, and I would use whatever is available to dress your eyeball up.
Good luck building!
The Instructables Book Contest
