Introduction: Ant Invasion Solution
Ants can be a huge problem in my area......one day not an ant in sight.....the next I might find a '2 inch wide column' of ants marching through my kitchen and swarming the dogs' feed dishes. Another problem spot is the shed where we store aluminum pop & beer cans for recycling.
I dislike spraying pesticides....they not only kill the ants, but beneficial insects as well. A borax, sugar & water 'syrup' is a very effective 'poison' for ants.
My solution was to build a container for the "ant syrup" that would allow easy access for ants, but not for birds, animals and other insects that might find that sweet syrup appealing......and its pretty secure from curious kids. I wanted something that could be used outside & withstand the elements....and the design to be such that evaporation wouldn't pose a problem (I wanted the syrup to stay syrupy)! And I wanted it to hold enough syrup that I wouldn't have to frequently refill it.
I wanted to set it in place & forget about it! This WORKED for 9 months on one filling.
Materials:
2 cans, one slightly shorter & smaller diameter than the other
foil duct tape
a kitchen 'scrubbie' (Scotch-brite pad type)
Borax (found in the laundry detergent aisle)
Sugar
Water
Tools:
can opener (the type that 'removes' the lid, rather than the kind that cuts into the lid)
large nail & hammer (to make access holes for the ants)...... or a drill & drill bit
scissors (to cut the 'scrubbie pad')
Step 1: "Remove" the Lid
Actually, the only lid that needs to be 'removed' is the lid to the outer can.
At the end of this process, the lid will be reattached.
Step 2: Scrubbie in Place
I cut a circle out of the scrubbie, and made a hole in the center (I wanted the ants to be able to get every last drop!). Then I put the remainder of the scrubbie in the can, the idea is that not only will they ingest the 'syrup', but will carry it back to their nest. I wanted them to have easy access to the syrup, and then back out again.
Add the 'syrup'......I used equal amounts of borax and sugar, added enough water to make a syrup. You can fill the inner can to nearly the top, just be careful to keep the can upright.
Step 3:
Make holes all around the outer can, about an inch from the opening.
Secure the inner can to the center of the lid of the outer can....hot glue gun, double faced tape, strong adhesive, bits of the foil tape....all will work.
Slide the outer can in place!
And press down firmly to seat the lid back into place.
Step 4: Taping It Securely Closed!
I chose this foil duct tape because it really withstands heat, cold, moisture & sunlight better than regular duct tape. Since I didn't really need tape this wide, I cut a length that went slightly more than halfway around the can & then cut it lengthwise.
If any of the holes get covered by the tape, be sure to poke a hole in the tape where it covered the holes.
Step 5: Done!
Now place this "Anti-Ant Weapon" where you need it.....indoors or out. I had this one 'zip tied' to an upright post in an open shed. Wherever you put it, make sure it won't get tipped over.....borax-syrup oozing out all over the place defeats the whole purpose of this Instructible!!!
You can paint the outer can....to keep it from rusting away (this can spent 9 months in exposed to the elements), or make it blend in to the surroundings....or to make it more noticeable.
Borax & sugar syrup to keep ants from invading is nothing new. It WORKS! But I like having it in a container that limits accessibility to other creatures.
This works wonderfully with fire ant infestations.....and they are more than just a 'nuisance'.
Instructables Design Competition
