Introduction: Antler Ring *WARNING: GRAPHIC IMAGES*
made this out of some antlers
Step 1: Cut the Antlers Off the Skull.
Carefully remove the antlers from the skull with the band saw... MAKE SURE YOU ARE EXTREMELY CAREFUL it is very easy to have a accident and have to go to the ER.... it happened to me while making it.. gave me 6 stiches.
Step 2: Cut the Hole in the Antler.
After you carefully take the antlers off, make the hole for the ring... this can be done using a dremel tool or a drill press.
Step 3: Cut the Desired Thickness and Sand
After making the ring hole, cut it the desired thickness with either the band saw or a hand saw.. then sand it to make it somewhat round
Step 4: Finish It Up
I then used the dremel tool with a sander drum bit to made the hole the right size, then I took the dremel tool with a sander disk and rounded it till it felt comfortable
Before and After Contest 2016
Valentine's Day Challenge 2016
