Apex Drone Card Stock Airplane
567
12
Introduction: Apex Drone Card Stock Airplane
About: Airplane enthusiast
This is the Apex Drone, one of a series of three. Unlike most of my other designs, no glue is needed to assemble them. Very fun for flying indoors!
Paper products have varying fibers and composition. If possible, compare samples of heavy card stock to see which is most rigid.
Supplies:
-Sheet of heavy (100 lb.) card stock, 8 1/2 " x 11"
-Vinyl-coated paper clip (standard size, no. 1)
-Clear adhesive tape
-Scissors
-Utility knife
-Metal ruler
Teacher Notes
Step 1: Download and Print
If you're printing onto regular 8.5" x 11" paper, you will need to then photocopy the document on card stock.
If you do not have card stock for printing, use a glue stick to laminate the printed paper with another sheet of paper.
Step 2: Cut Out the Pieces
Scissors will be your main tool. The knife and ruler are handy for tight corners. Once the three main pieces are cut out, carefully cut the narrow slits, making them about 1mm wide.
Step 3: Crease the Dotted Lines
The edge of a ruler is handy for this. Use one hand to clamp the piece to the ruler, and the other hand to gently work the free portion of the piece, and define the angle.
Whereas most of the dotted line are on the inside of their angles, the two lines that define the rudders/elevators of the tale are creased such that the dotted line is on the outside.
Step 4: Assemble the Nose
This step might be the most challenging. The tabs at the front must be made to interlock. Start with front of the nose first and then proceed to the windscreen. If struggling greatly, try widening the slit a little, or trimming down the sections that tuck down and behind the others.
Step 5: Add a Bit of Undercamber / Flaps
Using the rounded edge of a book, table, or cribbage board, apply gentle pressure to the leading and trailing edges of the main wing. In other words, the leading and trailing edges need to curl down slightly. This curl should be more pronounced at the trailing and on either side of the center line.
Step 6: Finish the Nose and Tail
Slide the vinyl-coated paper clip into place. Next, use a small piece of tape to join the two sides of the tail boom.
Step 7: Flights and Adjustments
Conduct some test flights indoors. Throw the plane straight and level, using just a little force. Use the rudder-elevators to influence the pitch. Use the whole tail to influence yaw by pinching the tape and nudging the tail boom slightly to the left or right.
This is a lightweight airplane. If flying outdoors, avoid breezy conditions, as well as trees and roofs.
CAUTION! A wingtip to the eye could cause serious injury. Be careful when throwing. If other people are around, allow a safe distance.
Be the First to Share
    • Cardboard Speed Challenge
    • Indoor Plants Challenge
    • Sculpting Challenge
      Sculpting Challenge
