Apple AirPlay Server on Your Raspberry Pi
Introduction: Apple AirPlay Server on Your Raspberry Pi
About: Born in Austria. Began to learn coding in 2015. Passionate software developer ever since. Skilled at Javascript, PHP, C#, Java and C. Always excited to learn new things.
AirPlay lets you share music from Apple devices to your favourite speakers. You can set up your own AirPlay Server on your Raspberry Pi and connect it to your favourite speakers.
Step 1: Equipment List
For your AirPlay Server you need the following equipment:
Recommended:
Step 2: Construction
  1. Connect the speakers to the 3.5mm audio jack (I personally recommend these speakers, because they do not need to much space and have a pretty good sound)
  2. Set up the Raspberry Pi
    How to set up the Raspberry Pi?
Step 3: Check for Updates
Type in this command to check for updates:
sudo apt-get update
Step 4: Install All Necessary Packages
  1. Install the dependencies
    sudo apt-get install autoconf automake avahi-daemon build-essential git libasound2-dev libavahi-client-dev libconfig-dev libdaemon-dev libpopt-dev libssl-dev libtool xmltoman
  2. Clone the shairport repository
    git clone https://github.com/mikebrady/shairport-sync.git
Step 5: Install Shairport
  1. Navigate to the cloned folder
    cd shairport-sync
  2. Build the program
    autoreconf -i -f
    ./configure --with-alsa --with-avahi --with-ssl=openssl --with-systemd --with-metadata
  3. Compile the program
    make
    sudo make install
Step 6: Enable Shairport to Start on Boot
  1. Register the service
    sudo systemctl enable shairport-sync
  2. Start the service
    sudo service shairport-sync start
    (From now on the service will automatically start on boot)
Step 7: Customize Your AirPlay Server
You can change the name of your AirPlay Server by editing the file 'shairport-sync.conf' in '/usr/local/etc'
sudo nano /usr/local/etc/shairport-sync.conf
  1. Delete the two slashes (//) in front of the name variable (where name = "%H")
  2. Change the "%H" to a name of your choice (e.g. "Living Room")
You can also set a password to your AirPlay server and many other options in the 'shairport-sync.conf'
That's it! You can now connect your iPhone or iPad to your new AirPlay Server. Have fun with it!
If you have any questions, don't hesitate to contact me.
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
    • Audio Challenge 2020
    2 Discussions
    Eli_Niemann
    Eli_Niemann
    Question 3 months ago on Step 5
    How do you start “make” part? I got to this and got stuck as it says there’s no target specified.
    alexposcher
    alexposcher
    Answer 2 months ago
    Hi Eli_Niemann,
    Thank you for your interest in my project and sorry for the late answer. Please make sure you are in the shairport-sync folder to execute the make command. I have found this page on the internet. Maybe it will help you: https://askubuntu.com/questions/103348/error-when-installing-makefile-make-no-targets-specified-and-no-makefile
    If you still have problems after trying this you can contact me via direct message and we can work this out together.
