Introduction: Ardublock Obstacle Avoiding Robot
This instructable tutorial is about "How To Build An Arduino Obstacle Avoiding Robot".Youtube video that I've uploaded recently. I strongly recommend you to check it out. Let's get started !
Step 1: A Chassis!
In first step,construct chassis by using 3-D printer or buy from any online electronics website.I got mine from instock.pk and i'll also mention link below.You can also make your own chassis by cardboard and DC/Servo motor.Chassis comprises body,two motors,battery holder,bread board and switch.
Step 2: Component Description
We will use the Arduino uno board and an ultrasonic sensor. If the robot detects an object infront of it, with the help of a small servo motor, it scans the area left and right in order to find the best way to turn.
For this project you will need:
Arduino UNO
Mini breadboard
L298N motor driver module with 2x dc motors with wheels
HC-SR04 ultrasonic sensor
Micro servo motor
9V battery holder (with power jack)
10 jumper wires
10 nuts and 10 screws
Step 3: Circuit Diagram by Using Fritzing
Step 4: Construction
- Use the screws, and nuts to attach the Arduino uno board and the L298N module on chassis. The mini breadboard can be easily attached on it with the glue.
Attach the tiny servo motor infront side of robot and place ultrasonic sensor on it.
Step 5: Code by Using ArduBlock
Step 6: Completed!
Now you have your own Arduino Obstacle Avoiding Robot!!!
Step 7: Note
- As the project is based on Arduino, the programming is very easy and can be easily modified.
- Doesn’t require the Arduino Motor Shield.
- When using a 9V battery, at least 2 such batteries are needed to power the robot. It is better to use 2 9V batteries (one for Arduino, Ultrasonic sensor, Servo Motor and the other one for L293D and motors).
- The Ultrasonic sensor should not be connected directly to power supply as it might affect the normal performance.
Design For Kids Challenge
Workshop Hacks Challenge 2017
Arduino Contest 2017
