Arduino Arcade Servo
Supplies needed:
*Arduino module (any with PWM)
*Breadboard
*Diode (optional - just in case)
*External power source
*Joystick
*Servo
*Wires
*& USB cord that might have come with Arduino
Teacher Notes
Step 1: Wiring
Connect the cable from the Joystick to the Arduino (wiring may vary, use your datasheet or experiment with LEDs to figure out your wiring or use the Arduino with the basics with a digital button example). My wiring is like in the picture up above. The servo's yellow wire goes to Arduino pin 52, this is not set and stone, so you can change it if you need or want to. The servo's red wire goes to the INDEPENDENT 5V source. The black wire from the servo goes to the GND of BOTH the Arduino & 5V source. Make sure to also connect a power supply to your Arduino when you are finished uploading your sketch, or leave it on your computer, your choice.
Step 2: Code
#include "Servo.h" // define the Servo library
#define Up 44 // Define joystick wiring
#define Down 45
#define Left 46
#define Right 47
Servo Servo1; // define servo object
void setup() {
pinMode(Up, INPUT_PULLUP); // define the pins of the joystick as input with
pinMode(Down, INPUT_PULLUP); // a pullup resistor which basically reads the joystick better
pinMode(Left, INPUT_PULLUP);
pinMode(Right, INPUT_PULLUP);
Servo1.attach(52); // attach the servo to pin 52 }
void loop() {
while (digitalRead(Up) == LOW){ // while the "Up" button is pressed
Servo1.write(90); // make the servo go to 90 degrees or a right angle
} digitalWrite(52, LOW); // Make the pin go low for no holding torque or holding position the
same technique goes for the rest just different angles
while (digitalRead(Down) == LOW){
Servo1.write(90); }
while (digitalRead(Left) == LOW){
Servo1.write(0);
while (digitalRead(Right) == LOW){
Servo1.write(180); }
digitalWrite(52, LOW); }
Step 3: Questions?
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
