Arduino Automated Car Parking System.
About: A Computer Science and Engineering student and a Hobbyist. love to make robots,electric devices,diy things and Programming them by Myself. My youtube channel https://www.youtube.com/fussebatti Follow me on ...
An Arduino Automated Car Parking System that is too easy and too fun to make. When a car arrives it shows the number of empty slots (if available) and then opens the gate. if there is not any empty slot then the gate does not open. Amazing thing is that the whole project can just be POWERED using a POWER BANK!!
Watch the video for the full tutorial.
Note: you can use display instead of my hand made led sign display.
Now lets get started.
Teacher Notes
Step 1: Parts
  • Arduino - any board
  • Infrared proximmity sensor (pic 2 & 3 - both are functional)
  • 330r resistor
  • some LED's
  • Servo motor - any model or size you wish.
Step 2: Making the LED Display
To make this LED display I have used a piece of bredboard then soldered the LED's and the 330r resistor. Then just added a ribbon cable for nice finish.
NOTE: I soldered the resistors on back so that they cant be seen from front to make the display .
It would be better if you use LCD display or cheap OLED display instead of this. I had not any,so I made this.
Step 3: Making the Parking Garage
To make this I have used a card board box then cut it to make a nice slope. Then added a piece of cardboard on to the servo motor and hot glued it. Added one sensor on the entrance and another on each SLOT. Then hot glued two chopsticks with the display we have made and glue it to the box. And of course as we will use the usb cable of arduino to power the whole project cut some area of the box to access to that port.
Don't forget to paint it a little bit.
Step 4: The Circuit
It looks a bit mess for the LED's but tell you what, this is really very much simple circuit.
NOTE: Proximity sensors use 5v to operate so you can just connect them to 5v source of arduino.
But what theee!! whay has he connected servo to VIN!! Let me explain you. Power banks usually supplies 5v 1Amp current which is input to arduino via the usb cable, now there is a voltage regulator on arduino which gives .5Amp to the board. By connecting to VIN we are actually accessing the power from the power bank without an breadboard. This works and safe.
Step 5: The Code
Upload the following code to the arduino
download code https://github.com/ashraf-minhaj/Automated-Parking...
or copy from below
/*Automated Parking Garage by Ashraf Minhaj. www.youtube.com/c/fusebatti
* for any query please mail me at ashraf_minhaj@yahoo.com*/
#include //adding Servo library Servo gate; //you may open or close gate using a Servo motor int slot1 = 5; //Connect IR sensor on digital pin5 for sLOT 1 int slot2 = 4; //sLot2 pin on digital 4 int gateSensor = 3; //IR sensor on gate to arduino pin 3 int slot1_l = 13; int slot2_l = 12; int gate_grn = 11; int gate_red = 10;
void setup() { gate.attach(7); //connecting the gate servo on pin 5 pinMode(slot1,INPUT); //setting slot pins & gate IR sensor as input to arduino pinMode(slot2,INPUT); pinMode(gateSensor,INPUT); pinMode(slot1_l,OUTPUT); pinMode(slot2_l,OUTPUT); pinMode(gate_grn,OUTPUT); pinMode(gate_red,OUTPUT); Serial.begin(9600); //initialzing Serial monitor
void loop() { //the car arrives and sensor goes LOW
if( !(digitalRead(gateSensor)) && digitalRead(slot1) && digitalRead(slot2)) //slot1 & slot2 empty { Serial.println("Welcome, Available: sLOT1, sLOT2"); //print slot1 and slo2 available digitalWrite(slot1_l,HIGH); digitalWrite(slot2_l,HIGH); delay(1000); digitalWrite(gate_grn,HIGH);
gate.write(75); //gate will open after the dealy of 1 second
if( !(digitalRead(gateSensor)) && !(digitalRead(slot1)) && digitalRead(slot2)) //car on slot1,slot2 free { Serial.println("Welcome, Available: sLOT2"); // slo2 available digitalWrite(slot1_l,LOW); digitalWrite(slot2_l,HIGH); delay(1000); digitalWrite(gate_grn,HIGH); gate.write(75); //gate will open after the dealy of 1 second } if( !(digitalRead(gateSensor)) && digitalRead(slot1) && !(digitalRead(slot2))) //car on slot2,slot1 free { Serial.println("Welcome, Available: sLOT1"); // slo1 available digitalWrite(slot1_l,HIGH); digitalWrite(slot2_l,LOW); delay(1000); digitalWrite(gate_grn,HIGH); gate.write(75); delay(100); //gate will open after the dealy of 1 second }
if( !(digitalRead(gateSensor)) && !(digitalRead(slot1)) && !(digitalRead(slot2))) { Serial.println("Welcome, Parking Full");// No slot available digitalWrite(slot1_l,LOW); digitalWrite(slot2_l,LOW); delay(1000); digitalWrite(gate_red,HIGH); delay(100); digitalWrite(gate_red,LOW); delay(100); digitalWrite(gate_red,HIGH); delay(100); digitalWrite(gate_red,LOW); } if( digitalRead(gateSensor)) { Serial.println("Welcome"); // slo2 available gate.write(5); //gate close digitalWrite(slot1_l,LOW); digitalWrite(slot2_l,LOW); digitalWrite(gate_red,LOW); digitalWrite(gate_grn,HIGH); delay(100); digitalWrite(gate_grn,LOW); delay(100); } }
Step 6: Finished
Now power the project using a USB cable to arduino and have fun.
Let me know how you are thinking to upgrade this and why.
Thank you.
Creative Misuse Contest
    • Indoor Lighting Contest
    • Make It Fly Challenge
    • Growing Beyond Earth Maker Contest
    11 Discussions
    gaurikardile171
    4 months ago on Step 6
    I have some issues with my mechatronics related project. Need your help. Plz revert back asap.
    Waiting for your reply.
    Ashraf Minhajdurgeshgavaskar
    Reply 4 months ago
    This is not supposed to be showed. Do not copy the code. Pleas download from github.
    abhi-jyo_1205
    Question 5 months ago on Step 5
    Hello sir,
    The code had worked for everything but the servo motor is rotating continuously. Can you please tell us why is it so ?
    Ashraf Minhajabhi-jyo_1205
    Answer 5 months ago
    Moving continuously means? Does it go back and forth over and over again? Then it means there is a POWER issue. Use different power source for the servo motor then.
    abhi-jyo_1205Ashraf Minhaj
    Reply 5 months ago
    gate.write(5) -> how gate will close by this code can you please tell us??
    Reply 5 months ago
    write(5) means write the servo to 5 degree, I placed the servo in a way so that it remains closed at 5 degree.
    AmitC83
    Question 6 months ago on Introduction
    What calculations are required for this project and codes according to diffrent countries?
    1 answer
    Ashraf MinhajAmitC83
    Answer 6 months ago
    I don't know about a lot about other countries , some parking garages (real life application) count the cars entry and exit thus determine how many slots are empty. But it can't say which slot is and where to go. This prototype can.
