Arduino Base
I was experimenting with my Arduino, and became worried about accidentally making contact with the back of the board. I looked up "Arduino Base" for purchase and realized I had everything I needed to build my own.
Supplies:
full breadboard
6V, 4AA battery pack
acrylic board, 6" by 7½"
4× tiny nuts
4× ¾" bolts
4× ½" spacers
double-sided tape
4× rubber feet
Teacher Notes
Step 1: Prepare the Board
Cut the acrylic board to size and sand the edges and corners. Use the Arduino as a template to mark and drill holes.
Step 2: Attach the Pieces
Attach the Arduino to the board with the bolts, using the ½" spacers to lift it off the surface of the acrylic board. I put the nuts on the back. I would have preferred plastic spacers, but I only had aluminum ones.
Peel the backing off the breadboard and affix it in place.
Use double-sided tape to affix the battery pack. My pack even had an on/off switch which is quite handy.
Finally, put rubber feet on the back of the board to prevent slippage and to prevent the nuts from contacting your work surface.
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
