Arduino Battery SMBus Reader
Introduction: Arduino Battery SMBus Reader
A simple SMBus reader for most smart batteries
Reads the data from the TI chip set used in many smart battery packs
http://www.ti.com/lit/gpn/bq29312
Teacher Notes
Step 1:
The 2x 1K resistors on data and clock inputs can be removed if you can’t get data
This was added for protection during testing other batteries with USB connection.
Step 2:
Original code was downloaded some time ago and heavily modified for formatting on Nokia display and getting data from larger battery packs (up to 8S)
Included the libraries that I used as these seem to change over time and the original code won't
More details are displayed via the Arduino Serial Monitor
Note the cell voltage displays 3 digits
Eg 356=3.56 volts
Cy = Cycles
CC = Current Capacity
DC = Design Capacity
DV = Design Voltage
V = Current Voltage
Step 3:
Build a Tool Contest
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
    2 Discussions
    rossingtown
    rossingtown
    Question 5 months ago on Introduction
    Hi PB The board you gave me for the coffee, I managed to break the 5110 display and got one form ebay but when I run the arduino I get all pixels on.
    Is the code here the same as what I have on this nano?
    I want to try uploading the program again with different contrast values.
    Thanks
    Ross
    pbtech
    pbtech
    Answer 4 months ago
    Yes . It’s the same code. It looks like the Arduino isn’t talking to the Nokia display properly. Recheck all connections.
    Edit - great to see you got it working again
