Introduction: Bluetooth RC Car by Ardumotive
This is our new Bluetooth RC car - based on our favorite Arduino UNO! In this project as you can see we used a custom-made PCB board and the ATmega328p micro controller. The board is specially design for this project and for small RC models. You can simple control it from your Android phone or tablet via Bluetooth. From the Android application you can also turn on/off the front and rear lights and play a horn sound! For our RC model we used only 3x1.5V AA batteries!
Project updates and more Arduino projects can be found here:
http://www.ardumotive.com/arduino-bluetooth-rc-car...
Here is a video from our RC car with assembly/soldering instructions!
Step 1: What You Will Need - Hardware
For this project you will need:
- Our custom PCB circuit (find it in next step)
- Atmega328 (with Arduino UNO bootloader)
- 28 pin dip socket & 2x 16 pin dip socket
- 2x L293 IC or SN754410
- 16 MHz crystal oscillator
- 10 uF capacitor
- 2x22 pF ceramic capacitors
- 10 kOhm resistor
- Buzzer
- Bluetooth module HC-06 (or HC-05)
- 4x screw terminal 2P 2.54mm
- Pin header 1x5 Female
- Pin header 1x40 Male
You will also need a TTL to USB module or an Arduino UNO board for the programming procedure.
Step 2: Circuit Schematic
Order it from pcbway.com and get 10pcs PCB for free! (only for new members)
Instructions on how to order it can be found in the video that we have in first step.
You can also make your changes here:
Step 3: The Code
Connect your circuit with the TTL to USB module with 5 cables to the programming header or insert the atmega328 IC to your Arduino UNO board and upload the code! (after the programming procedure remove it and install it again to our custom pcb board).
/* Arduino Bluetooth Car<br> * Created by Vasilakis Michalis // updated: 31/7/2019 * More information at www.ardumotive.com */ #include //Software serial connection for bt module SoftwareSerial btSerial(A2,A3); // RX & TX
//L293 Connection const int motorA1 = 5; // Pin 2 of L293 const int motorA2 = 3; // Pin 7 of L293 const int motorB1 = 11; // Pin 10 of L293 const int motorB2 = 10; // Pin 14 of L293 //Leds connected to Arduino UNO Pin 12 const int front_lights = 8; const int back_lights = 7; //Buzzer / Speaker to Arduino UNO Pin 3 const int buzzer = 2 ;
//Useful Variables int i=0; int j=0; char state;
void setup() { // Initialize serial communication at 9600 bits per second: btSerial.begin(9600); Serial.begin(9600); // Only for debugging // Set pins as outputs: pinMode(motorA1, OUTPUT); pinMode(motorA2, OUTPUT); pinMode(motorB1, OUTPUT); pinMode(motorB2, OUTPUT); pinMode(front_lights, OUTPUT); pinMode(back_lights, OUTPUT); delay(500); //Stop all motors digitalWrite(motorA1, LOW); digitalWrite(motorA2, LOW); digitalWrite(motorB1, LOW); digitalWrite(motorB2, LOW); } void loop() { //Save income data to variable 'state' if(btSerial.available() > 0){ state = btSerial.read(); Serial.println(state); } /***********************Forward****************************/ //If state is equal with letter 'F', car will go forward! if (state == 'F') { digitalWrite(motorA1, HIGH); digitalWrite(motorA2, 0); digitalWrite(motorB1, 0); digitalWrite(motorB2, 0); Serial.println("Moving Forward"); } /**********************Forward Left************************/ //If state is equal with letter 'G', car will go forward left else if (state == 'G') { digitalWrite(motorA1, HIGH); digitalWrite(motorA2, 0); digitalWrite(motorB1, HIGH); digitalWrite(motorB2, 0); Serial.println("Moving Forward Left"); } /**********************Forward Right************************/ //If state is equal with letter 'I', car will go forward right else if (state == 'I') { digitalWrite(motorA1, HIGH); digitalWrite(motorA2, 0); digitalWrite(motorB1, 0); digitalWrite(motorB2, HIGH); Serial.println("Moving Forward Right"); } /***********************Backward****************************/ //If state is equal with letter 'B', car will go backward else if (state == 'B') { digitalWrite(motorA1, 0); digitalWrite(motorA2, HIGH); digitalWrite(motorB1, 0); digitalWrite(motorB2, 0); Serial.println("Moving Backward"); } /**********************Backward Left************************/ //If state is equal with letter 'H', car will go backward left else if (state == 'H') { digitalWrite(motorA1, 0); digitalWrite(motorA2, HIGH); digitalWrite(motorB1, HIGH); digitalWrite(motorB2, 0); Serial.println("Moving Backward Left"); } /**********************Backward Right************************/ //If state is equal with letter 'J', car will go backward right else if (state == 'J') { digitalWrite(motorA1, 0); digitalWrite(motorA2, HIGH); digitalWrite(motorB1, 0); digitalWrite(motorB2, HIGH); Serial.println("Moving Backward Right"); } /***************************Left*****************************/ //If state is equal with letter 'L', wheels will turn left else if (state == 'L') { digitalWrite(motorA1, 0); digitalWrite(motorA2, 0); digitalWrite(motorB1, HIGH); digitalWrite(motorB2, 0); Serial.println("Turn Left"); } /***************************Right*****************************/ //If state is equal with letter 'R', wheels will turn right else if (state == 'R') { digitalWrite(motorA1, 0); digitalWrite(motorA2, 0); digitalWrite(motorB1, 0); digitalWrite(motorB2, HIGH); Serial.println("Turn Right"); } /************************Lights*****************************/ //If state is equal with letter 'W/w', turn front leds on or of off else if (state == 'W') { digitalWrite(front_lights, HIGH); Serial.println("Turning front lights ON"); } else if (state == 'w') { digitalWrite(front_lights, LOW); Serial.println("Turning front lights OFF"); } /************************Lights*****************************/ //If state is equal with letter 'U/u', turn back leds on or of off else if (state == 'U') { digitalWrite(back_lights, HIGH); Serial.println("Turning rear lights ON"); } else if (state == 'u') { digitalWrite(back_lights, LOW); Serial.println("Turning rear lights OFF"); } /**********************Horn sound***************************/ //If state is equal with letter 'V', play (or stop) horn sound else if (state == 'V'){ tone(buzzer,500); Serial.println("Playing horn sound"); } else if (state == 'v'){ noTone(buzzer); Serial.println("Stop playing horn sound"); } /************************Stop*****************************/ //If state is equal with letter 'S', stop the car else if (state == 'S'){ digitalWrite(motorA1, 0); digitalWrite(motorA2, 0); digitalWrite(motorB1, 0); digitalWrite(motorB2, 0); Serial.println("STOP"); } }
Step 4: Android Application
To control your new Bluetooth car, download and install this android application
https://play.google.com/store/apps/details?id=braulio.calle.bluetoothRCcontroller
Credits for the Android App goes to Andi.Co! Thank you for sharing!
First enable Bluetooth and establish connection with BT module (pair it with your phone from bluetooth settings).
(ex. HC-06, password 1234)
Note: From the settings menu select the "On change/touch" option and then press the save button
Functions that are working with this project:
- 8 Direction buttons
- Speaker button for horn sound
- Front lights button
- Rear lights button
Step 5: Well Done!
That's it!
I hope you liked this, let me know in the comments!
I would also like to see some photos from your new BTremote control car !
Games Contest
