Introduction: Arduino Clapswitch LAMP
PLEASE VOTE! ME IF YOU LIKE IT
Hi, this is my new Arduino clap switch lamp. This works as a Night-Light or even as an Emergency Lamp. It is powered by a 9v adapter. This lamp is very useful in our daily life and easy transportation. Double clap to turn on and again double clap to turn off. Though It runs with a single led it gives more light. You can also replace the single led with strips.
Step 1: YOU WILL NEED:
1.a plastic cylindrical box(optional)
2. a brighter led
3.a 9v adapter or an usb cable or battery
4.arduino board
5.mic
6.some jumper cables
Step 2: Attach the Arduino and the Mic Into the Box As Shown
Step 3: Now Attach the Led to the Cap With Tape or Glue
Step 4: Wiring
1.connect the +ve end of the led to the digital-pin 8.
2.connect the -ve end of the led to the gnd.
3.connect the vcc of the MIC to 3.3v.
4.connect the gnd of the MIC to the gnd.
5.connect the OUT of the MIC to the digital-pin 10.
Step 5: CODE
copy,paste on the ide..........
int clap = 0;
long detection_range_start = 0;
long detect_range = 0;
boolean light_state = false;
void setup(){
pinMode(2, INPUT); //mic
pinMode(8, OUTPUT); //led }
void loop(){
if(digitalRead(2) == 0){
if(clap == 0){
detection_range_start = detect_range = millis();
clap++;
else if(clap > 0 && millis() - detect_range >= 49){
detect_range =millis();
clap++;
if(millis() - detection_range_start>= 399){
if(clap== 2){
if(!light_state){
light_state = true;
digitalWrite(8, HIGH);
}else if(light_state){
digitalWrite(8, LOW); } }
clap = 0; } }
Step 6: You Are Done.
Arduino Contest 2016
First Time Authors Contest 2016
