Arduino Controlling Multiple P.I.R Sensor on Same Bord
Today I will tell you how to connect multiple PIR Sensors with single Arduino Bord
>here i have also used 4 channel relay module for some extra functionality.
ARDUINO + 4 Channel Relay Module + 4 PIR Sensor (OR You can used as many pin your arduino has )
Teacher Notes
Step 1: Hardware Required
Step 2: Hardware Connection
Arduino________________TO_____________________PIR SENSORS(PIR1,PIR2,PIR3,PIR4)
Arduino PIN 3........................................PIR1-output pin
Arduino PIN 4........................................PIR2-output pin
Arduino PIN 5........................................PIR3-output pin
Arduino PIN 6........................................PIR3-output pin
Arduino 5v..............................................PIR1,PIR2,PIR3,PIR4(VCC )//connect all Vcc pin of pir1, pir2 , pir3 , pir4
//to the Arduino 5 v
Arduino GND..........................................PIR1,PIR2,PIR3,PIR4(GND )
ARDUINO________________TO________________________REALY MODULE
Arduino PIN 9.................................................................IN1 RELAY
Arduino PIN 10.................................................................IN2 RELAY
Arduino PIN 11...............................................................IN3 RELAY
Arduino PIN 12................................................................IN4 RELAY
Arduino GND..................................................................Relay GND
Arduino Vin.....................................................................Relay VCC
12 v -2A Power Supply .................................................to...........................................Relay Model 12v Input &GND (Some Relay Module Does not have 12 v power input so you need a 12 v to 5 v converter ......or you can distribute power by yourself .
Step 3: Programming Part
Here Programming is most important part
while in this project I face lots of problem in programming only.
  • here i have used a Arduino internal pulled up resistor
  • I used (IF-Statement) Without else Statement for stability
If you face any problem do not forget to comment
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
