Arduino Decibel Meter
About: hIOTron is an IoT Based company that offers IoT Platforms, IoT Solutions, IoT Training.
This project will help you to monitor the noise or sound level by measuring sound pressure.
Supplies:
Hardware Components
1. Arduino Microphone
2. Arduino Uno
3. Jumper wires
4. Dashboard
5. Green LED X5
6. Yellow LED X3
7. Red LED X2
8. Resistor 200ohm
Software
Arduino IDE
Teacher Notes
Step 1: About Project
The purpose of the decibel meter is to access the noise or sound level by measuring sound pressure.
The Microphone must have an analog output. Make connections as shown in above dig using the breadboard and make sure you are properly connecting the LEDs with resistors.
Use male-male cables to connect everything. The microphone module can also be plugged into the breadboard. Run a Code as mentioned below.
The first loop is for the LEDs setup and the second is to control the LEDs. You can customize the sensitivity by changing the value in the map function.
IoT Training Online will help you to learn all such new concepts with its IoT Applications over various industries.
Step 2: Run a Program
void setup() {
//here is an input for sound sensor
pinMode(A0, INPUT);
//here we are setting up all pins as an outputs for LEDs
for(int z = 0; z < 10; z++){
pinMode(z, OUTPUT); } }
void loop() { /
/here we are storing the volume value
int volume = analogRead(A0);
//max value for analog read is 1023 but it must be very very loud to reach this value
//so I lower it down in map function to 700
//mapping volume value to make it easier to turn LEDs on
volume = map(volume, 0, 700, 0, 10);
//for loop to turn on or off all LEDs
//thanks to this loop code for this project is very short
//we are going through all pins where we have LEDs and checking if the volume is
//bigger then pin number (that's why we are maping the volume)
for(int a = 0; a < 10; a++){ if(volume >= a){
//if it is bigger we can turn on the LED
digitalWrite(a, HIGH);
}else{
//if it is smaller we can turn the LED off
digitalWrite(a, LOW);
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
