Arduino Electric Drums / Drum Machine
Introduction: Arduino Electric Drums / Drum Machine
This tutorial on how to build an set of electric drums, is an entry into the Makey Makey competition.
material, will vary on availability and personal choices. Cardboard can be replaced with more durable materials, and layered with foam/ other for texture. Chop sticks can be replaced with wood, real drum sticks, or other. Alligator connection clips can be replaced with more durable / permanent wire. These steps are not shown because, the steps shown are in my opinion, the most available supplies, and easiest to make. Drum "Holder" / "Stand"
Teacher Notes
Step 1: Step 1: Drawing Drum Head
Take you first piece of cardboard, and flip to the brown, ("Un-colorful") side.
On the brown side, draw a large, drum (depends on what type of drum you are making), with a small square attached.
Step 2: Step 2: Cut Out Drum
Cut out the drum, along the previously drawn line.
Step 3: Step 3: Aluminum Foil
Wrap the freshly cut out drum, in Aluminum foil.
(Also wrap the "Square")
Step 4: Step 4: Dum Sticks
Seperate the chop sticks
(optional) sandpaper or rub chopsticks on each other, to remove any possible splinters. Wrap the chop sticks in aluminum foil and attach wires or Alligator clips.
Step 5: Step 5: Kick Drum / Pedal
Draw a rectangle large enough to fit around foot.
Afterward cut out the rectangle
Step 6: Step 6: Kick Drum Thing
Tape the rectangle to fit around foot.
tape / attach aluminum foil
Step 7: Step 7: Wiring
Attatch: "Kick pedal" and "Drum Sticks" to "Earth" on the Makey Makey
Attach: Drum head to appropriate "Slot" / (Up arrow, Space, Down Arrow, etc.) Clip alligator clips to "square" on drum head.
Step 8: Step 8: Scratch
Create a scratch account
Create Makey Makey blocks and link them to the appropriate Makey Makey Controle (up arrow, down arrow, space, etc) and appropriate drum sound. Example: link kick drum sfx to up arrow. Link physical, kick drum head, to up arrow, and kick for foot, link to ground. customize timing, to preferences
Be the First to Share
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    3 Discussions
    Penolopy Bulnick
    Penolopy Bulnick
    25 days ago
    Hi!
    This appears to be a duplicate of your other Instructable and has been unpublished to avoid confusion.
    Best,
    Nicole
    Community Manager
    DI_Prod
    DI_Prod
    Reply 24 days ago
    ok, thank you, I just made this one because I was confused why, my other instructable was not entering the Makey Makey competition
    Penolopy Bulnick
    Penolopy Bulnick
    Reply 24 days ago
    Hi! No problem, that can happen sometimes if you get caught in the filter. Your other project should be set to enter the Contest :) Just go right to the contest page and click Enter Now!
