Arduino Flame Sensor Fire Alarm System (4 Steps)
Hi friends, This is Anto. in this tutorial, we can able to learn how to connect flame sensor to the arduino board and make an Fire alarm system. The sensor i used is more accurate and works perfect. Follow the entire tutorial, Connect the hardware as per the circuit. you can also able to make the fire alarm system.
Supplies:
I strongly suggest you to buy the hardwares from UTSource. since their products are good quality and more affordable. Enjoy buying from them with cheapest prize.
arduino 1 x 1
Flame Sensor 1 x 1
LCD 1 x 1
LCD breakout board 1 x 1
Buzzer 1 x 1
LED 1 x 1
Bread board 1 x 1
220 ohm resistor 1 x 1
jumpers few nos
Teacher Notes
Step 1: Connect A0 Pin of the Flame Sensor to the A0 of the Arduino Board
We need the detection of flame in any distance. so that we need to connect the A0 pin of the flame sensor to the A0 of the arduino board. connect the LCD, buzzer, led as per the circuit diagram
Step 2: Connect the Positive of the Buzzer to the Vcc and Negative to the Arduino
I have connected the positive of the buzzer directly to the vcc to get enough power for the buzzer. we have to send low signal from the arduino to the buzzer to enable.
Step 3: Download the Arduino Code With Suitable Editing
Edit the heading to display on the lcd and download the code. the code is available on the attachment.
Step 4: Test the Hardware With the Flame
finally its done. i have measured the flame even if i showed beyond 1 Feet. you can hear the buzzer sound as well as led indication.
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
