Introduction: Arduino ROOMBA + Autonomous Steam Cleaner
So from high demand on reddit, I guess I’m making a tutorial for this! Here we go,
Step 1: Cutting Cardboard or If You Have a Chassis Use That.
Cut however but you want it to be!
I used 4x5 inches,
Next you’ll want to cut 2 small pieces of cardboard 3 inches long and 1 inch wide. Glue them together
Afterwards you’ll need a plastic vase for your cloth or rag.
Step 2: Assembly
You can use your Zip ties or Hot glue here
Step 3: Circuitry
Just follow the schematic I made for you and ask questions in the comments if you need!
Step 4: Programming
Just copy paste the code I gave you and if you need to change around the motor speeds to even the turns out go ahead!
#include //Adafruit Motor Driver Shield library
AF_DCMotor motor1(3); //motor1 connected to M3
AF_DCMotor motor2(4); //motor 2 connected to M4
long duration; //duration of ultrasonic pulse
int distanceCm; //distance in cm
void setup()
pinMode(A1, OUTPUT); //Analog pin A1 connected to TRIG
pinMode(A0, INPUT); //Analog pin A0 connected to ECHO
motor1.setSpeed(255); //motor speed set to max. range:0-255
motor2.setSpeed(255);
motor1.run(RELEASE); //stop both motors
motor2.run(RELEASE);
void loop()
digitalWrite(A1, LOW);
delayMicroseconds(2);
digitalWrite(A1, HIGH); //give a pulse of 10us on TRIG
delayMicroseconds(10);
duration = pulseIn(A0, HIGH); //check time elasped in receiving back the pulse on ECHO
distanceCm = duration*0.034/2; //convert to distance in cm
if(distanceCm <= 20) //if distance less than 20cm make the turn
motor1.run(FORWARD); //to turn motor to righ change to motor1.run(BACKWARD)
motor2.run(BACKWARD); //and motor2.run(FORWARD)
delay(500); //play with delay to set the angle of turn
else //else keep moving forward
motor2.run(FORWARD);
Step 5: Troubleshooting
So I’m guessing these will be your problems
-Wheels aren’t moving
Use a higher power battery, 9V will work for a little while but you’ll have to tweak the code to set the motor powers to 255.
-Constantly turning
Make sure your ultrasonic sensor is connected correctly!
Your motors may be on backwards, if so change them or change the directions in the code.
-Wheels don’t move but you hear a buzzing
Use more power!!!!!
-anything else
Leave it in the comments below!
Step 6: Finished
Put some water or windex in front of the cloth and you get this!
Arduino Contest 2020
