Arduino LED Ultrasonic Sensor
The LED Sonic Sensor is referenced to Interfacing Ultrasonic Sensor With Arduino.
The difference I added is a LED.
This is the LED Ultrasonic Sensor. When the object gets close to it a LED will become brighter. It can help you perceived a note of something or someone move nearer to you.
Supplies:
  • Arduino Leonardo (You can also use Arduino Uno)
  • Breadboard
  • Ultrasonic Sensor HC-SR04
  • LED
  • Resistor 220 Ohm
  • Male-to-male Jumper Wires
  • Male-to-female Jumper Wires
  • Corrugated Fiberboard (Or other decorating materials
  • Plastic box (Or other materials)
  • Double-sided tape
  • Cutter
  • Tape (Not necessary)
  • Foam tape (Not necessary)
  • Clay (Not necessary)
Teacher Notes
Step 1: Circult and Code
Connect everything to Arduino as shown in the picture.
Note:
  • VCC – > 5V (red)
  • TRIG – > 11 (yellow)
  • ECHO – > 10 (orange)
  • GND – > GND (black)
  • Other jumper wires (green)
Here is the code.
Step 2: Outer Case
Put the circuit board in a plastic box. You can also use other materials for the outer case.
Step 3: Insert the Sensor and LED
Drill two holes on the lid of a plastic box. Put the ultrasonic sensor and LED in.
Step 4: Firmly Fixed
I used foam tape, tape, and clay to snap on wires.
This is an unnecessary step
You can do it if you like:)
Step 5: Decorate
Decorate it whatever style you like! I used red corrugated fiberboard.
Here is the video of the finished LED Ultrasonic Sensor.
This will show how's it work.
Hope you like it:)
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
