Introduction: Arduino Lock Mechanism
This is a simple Arduino project that emulates a home security system.
It is fully simulated on Proteus though you should not expect much difference on a real environment.
You'll require:
- Proteus
- Atmel Studio
- Visual Micro for Atmel Studio
- Arduino IDE
You can just use Arduino IDE with Proteus but I prefer the complete set up to take advantage of:
- The .hex file is stored within the project folder
- Atmel Studio has compelling auto-complete features
Basically when the project loads you shall see a such a set-up
Step 1: Set-up, Code
#include
#include #include #include
int greenLed=22; int redLed=23; int servoPin=24;// Servo int piezoPin=25; char* ourCode="1234"; int currentPosition=0; Servo myservo; int pos = 0;
const byte rows=4; const byte cols=3;
char keys[rows][cols]={ {'1','2','3'}, {'4','5','6'}, {'7','8','9'}, {'*','0','#'} }; byte rowPins[rows]={13,10,9,8}; byte colPins[cols]={7,6,1}; Keypad keypad=Keypad(makeKeymap(keys),rowPins,colPins,rows,cols); LiquidCrystal Lcd (12,11,5,4,3,2);
void setup() { Lcd.begin(16,2); myservo.attach(24); displayCodeEntryScreen(); pinMode(piezoPin,OUTPUT); pinMode(servoPin,OUTPUT); pinMode(redLed,OUTPUT); pinMode(greenLed,OUTPUT); digitalWrite(redLed,LOW); digitalWrite(greenLed,LOW); }
void loop() { int l; char key=keypad.getKey(); Lcd.setCursor(0,0); Lcd.print(" ENTER PASSWORD "); if(int(key)!=0){ Lcd.setCursor(4,1); for(l=0;l<=currentPosition;++l) {Lcd.print("*");} if(key==ourCode[currentPosition]) { ++ currentPosition; if(currentPosition==4) {unlockDoor(); currentPosition=0; } } else{invalidCode(); currentPosition=0; } } } void invalidCode() { digitalWrite(redLed,HIGH); digitalWrite(servoPin,LOW); digitalWrite(piezoPin,HIGH); clearScreen(); Lcd.setCursor(0,0); Lcd.print("ACCESS DENIED!"); Lcd.setCursor(0,1); Lcd.print("INVALID CODE "); delay(5000); digitalWrite(redLed,LOW); digitalWrite(piezoPin,LOW);
displayCodeEntryScreen(); }
void turnHandle() { for(pos = 0; pos <= 180; pos += 1) // goes from 0 degrees to 180 degrees { // in steps of 1 degree myservo.write(pos); // tell servo to go to position in variable 'pos' delay(15); // waits 15ms for the servo to reach the position } for(pos = 180; pos>=0; pos-=1) // goes from 180 degrees to 0 degrees { myservo.write(pos); // tell servo to go to position in variable 'pos' delay(15); // waits 15ms for the servo to reach the position } }
void unlockDoor() { digitalWrite(greenLed,HIGH); clearScreen(); Lcd.setCursor(0,0); Lcd.print(" ACCESS GRANTED "); Lcd.setCursor(0,1); Lcd.print(" WELCOME!! "); digitalWrite(servoPin,HIGH); turnHandle(); delay(500); digitalWrite(greenLed,LOW); digitalWrite(servoPin,LOW); displayCodeEntryScreen(); } void displayCodeEntryScreen() { clearScreen(); Lcd.setCursor(0,0); Lcd.print(" HELLO AND "); Lcd.setCursor(0,1); Lcd.print(" WELCOME! "); delay(3000); clearScreen(); } void clearScreen() { Lcd.setCursor(0,0); Lcd.print(" "); Lcd.setCursor(0,1); Lcd.print(" "); }
Step 2: Welcome Screen
On a successful build the file should be stored in the following file directory eg :C:\Users\Username\Documents\Atmel Studio\6.2\ProjectFolder\ProjectName\Debug
The welcome screen is as shown...
Step 3: Password Request
Enter your password
In our Case 1234
Step 4: Access Granted
On successful entry
Step 5: Closing
After the motor moves to simulate door unlocking it will lock again and display home screen
