Introduction: Arduino Mood Light and Holder
Learn how to make your own Mood light out of an Arduino!!!
Step 1: Gathering the Materials
Your gonna want to gather these materials if you want to build the mood light:
1x Arduino Uno
1x RGB LED
3x 330 Omh Resistors
1x Breadboard
4x Jumper Cables
1x Milk Jug
The amount of wood depends on the size of the container you want to have! ;)
Step 2: Building the Container
First your gonna want cut out the base of your container:
I used two 2x4s with a length of 9 1/4 inches and used wood glue to put them together to hold it together.
After you cut out the base then your going to want to build the front and back sides:
For the sides I used once again two 2x4s per side with a length of 7 inches
For the bottom 2x4 on the back sides cut a opening in it to act as a storage for the future
On the front side your going to cut a spot for your phone to rest
You cut the rest depending on the size of your phone
After you cut out the resting spot then pit a piece of plywood to act as the support so your phone doesn't fall out
Then I connected them using wood glue
After you cut the front and back then you must cut out the sides:
I used 3/8 inch thick ply wood and cut it 7x7 inches per side
Then screw them into the front and back as shown above
You then going to cut a 6 inch long 2x4 and screw it into the back side of the container
Then your going to make the top of the box:
I used a piece of plywood which in my case was 10x7 inch
You will use the top later so don't screw it on yet
Step 3: Wiring
Connect long wires to the 10, 11, and 12 pins on the edge of your Arduino, and use the breadboard the link them to the resistors linked to the LEDS(as seen above). Run the GND pin on the Arduino to the black row on the breadboard (anywhere will do).
Step 4: Coding
Put this code into Arduino and verify to see if you did it right:
Step 5:
Then your gonna want to cut out the top the size of a half cut half gallon milk jug and put the arduino onto the shelf and put the jug on top
Then screw in the top
Enjoy!!!
First Time Author Contest 2016
