Introduction: Arduino Nano Compatible Robo-Geek Kits
About: Omar Silva-Zapata is co-founder of Robo-Geek Inc.
Congratulations on purchasing the Arduino Nano compatible Robo-Geek kit. In this tutorial, we will guide you how to get you started with Arduino Nano compatible board.
The Arduino Nano compatible Robo-Geek kit was designed for those new to Arduino world who are interested in micro-robotics. This is an introductory kit, therefore we assume no prior experience. Recommended age is 10 years with parent supervision.
Disclaimers
The information, materials and services provided on the Arduino Nano compatible Robo-Geek kit are provided "as is" without any warranties of any kind including warranties of merchantability, fitness for a particular purpose, or non-infringement of intellectual property. Neither Robo-Geek Inc. nor any of their affiliates warrant the accuracy or completeness of the information, materials or services provided on or through this web site. The information, materials and services provided on may be out of date, and neither Robo-Geek Inc, nor any of its respective affiliates makes any commitment or assumes any duty to update such information, materials or services. The foregoing exclusions of implied warranties do not apply to the extent prohibited by law. Please refer to your local laws for any such prohibitions.
All products and services purchased on only to any applicable warranties of their respective manufactures, distributors and suppliers, if any. To the fullest extent permissible by applicable law, we hereby disclaim all warranties of any kind, either express or implied, including, any implied warranties with respect to the products and services listed or purchased on or through this web site. Without limiting the generality of the foregoing, we hereby expressly disclaim all liability for product defect or failure, claims that are due to normal wear, product misuse, abuse, product modification, improper product selection, non-compliance with any codes, or misappropriation.
Robo-Geek Inc. does not approve or recommend the use of our products or resources in critical life-support or medical devices, or for any use or application in which the failure of a single component could create a situation in which property damage, personal injury or death is likely to occur. Don't hack your pacemaker! And if you do, you absolve Robo-Geek Inc. and/or the manufacturer of the product in question of all damages, costs, and expenses that may be incurred, including without limitation, attorney fees and costs related to any lawsuit or threatened lawsuit arising out of the use of our products in unauthorized applications.
Step 1: What Is Included?
The Arduino Nano compatible Robo-Geek kit includes the following:
1. Nano 3.0 compatible micro-controller with Arduino Nano CH340 USB driver x 1
2. USB cable Nano v3.0 x 1
3. 1.44 inch serial 128x128 SPI Color TFT LCD module x 1
4. Quality mini bread-board 8.5 cm x 5.5 cm 400 holes x 1
5. Ultrasonic module HCSR04 distance measuring transducer sensor x 1
6. 3mm color LED Diode x 10
7. male to male, male to female and female to female 20 cm Dupont cables x 6 of each type (total 18 cables)
8.1 K ohm 1/4 carbon film resistor 0.25 W 5% resistance
9. 6x6x5mm 4 pin mini-micro momentary tactile push button switch x 5
10. 8 x 6.2 x 3.9 inches clear accessory box with secure lid x 1
Step 2: Precautions When Working With Electronics
Common sense in many times is not common. If you are new to electronics, always follow instructions carefully.
1. Keep foods and liquids away
2. Don't work on a circuit while it is powered up.
3, Check your work before applying power the first time to avoid short circuits.
4. Avoid mains(wall socket) electricity unless you have proper training.
5. Consider removing rings, watches or jewelry to prevent shorts
6. Wash your hands before eating, some nasty chemicals are involved in the manufacturing process
7. Use an ESD wrist strap if desired or ground yourself first before handling a circuit.
Source: http://raspberrypi-aa.github.io/2014/09/10/session...
What is Electrostatic Discharge (ESD)?
Certain components used in electronic assemblies are sensitive to static electricity and can be damaged by its discharge. Static charges are created when non-conductive materials are separated, such as when plastic bags are picked up or opened, when friction occurs between articles of synthetic clothing, when plastic tapes are dispensed and many other causes.
Destructive static charges are induced on nearby conductors, such as human skin, and delivered in the form of sparks passing between conductors, such as when the surface of printed board assembly is touched by a person having a static charge potential. If touched at the right solder joint or conductive pattern, the circuit board assembly can be damaged as the discharge passes through the conductive pattern to a static sensitive component. It is important to note that usually the static damage level for components cannot be felt by humans.
Other General Precautions:
1. Keep your working area clean
2. Adult supervision is required when working with electronics
3.Wearing a wrist strap connected to earth ground.
4. Wearing 2 heel grounders and have both feet on a static dissipation floor surface
We highly recommend to read the following article before you proceed to the next step:
https://www.rugged-circuits.com/10-ways-to-destroy...
Step 3: Keep Your Area Clean
1. Tidy up your area BEFORE working on your project.
2. Tidy up your area AFTER you finish working with your project.
It sounds simple because it is!
Please take your time, small electronics can be a hazard for young kids and pets. Make sure everything goes back to the container. The container included in this kit is big enough to house your working projects so no reason to have cables or resistors to be all over the place. Be considerate to others and tidy up.
Step 4: Tutorials
The following links will point you to the tutorials, please complete in order. It's important to build up your comfort level and complete each tutorial.
Tutorial 1: Arduino Nano Compatible Robo-Geek Kits
Tutorial 1 refers to this tutorial. Important: Read all Steps in this tutorial before proceeding to Tutorial 2.
Tutorial 2: Getting Started with Arduino Nano
https://www.instructables.com/id/Arduino-Nano/
Tutorial 3: Turning LEDs on and off sequentially and simultaneously
https://www.instructables.com/id/Arduino-Nano-Comp...
Tutorial 4: Using Micro-switch to turn an LED
https://www.instructables.com/id/Arduino-Nano-Usin...
Tutorial 5: Using TFT 1.44 with Arduino Nano
https://www.instructables.com/id/Using-TFT-144-Wit...
Tutorial 6: TFT 1.44 ARDUINO NANO - MORE EXAMPLES
https://www.instructables.com/id/TFT-144-Arduino-N...
Tutorial 7: HCSR04 with LED
https://www.instructables.com/id/Ultrasonic-Sensor...
Tutorial 8: Distance Display Monitor
Coming Soon! Stay tuned.
Step 5: Where to Order the Kits and How to Contact Us?
If you are interested in purchasing the Arduino Nano compatible Robo-Geek kits, please contact us at:
info@robo-geek.ca
Currently we only distribute in Canada.
