Arduino Night Light
The original publisher of this project is: ENG249GroupProject
and this is the link of the original publisher's website
This night light is use for people who are afraid of darkness and it won't be too dazzling.
I added a yellow LED to make the night light looking not that boring.
Another change I made is I made the lamp bigger, so it can cover the breadboard.
Teacher Notes
Step 1: Step 1: Tools and Materials
Tools
a computer with USB port
pencil
ruler
scissors
box cutter
Materials
x1 Arduino board with a USB connection cable
x1 Breadboard
x1 common anode RGB LED
x3 220 Ohm resistors
8 wires
thick opaque paper
thin translucent paper (graph paper)
glue
Step 2: Step 2: Making the Lamp
Rectangle paper
Take a A4 size paper and cut the paper into a rectangle of length 30 widths 15.
Fold in half and cut a little triangle at the line you just fold.
Measure 12cm at the side of 15cm, fold in the 1.5cm in each side.
Last, cut off four small triangle in each corner.
Triangle paper
Take another paper and cut it into a triangle with two sides being 14.5cm and the other side of 20cm. (you need two of this, so make two)
Draw two smaller triangle on the triangle you just cut off.
Take the white (note paper) and cut it into a triangle that is a little smaller than the thick paper. (you need two)
Stick them together
Combine the Rectangle and Triangle paper
Ding! You made it !
Step 3: Code
https://create.arduino.cc/editor/AlisaLiang/d992f9...
Arduino night light code
const int redLEDPin = 9;
const int greenLEDPin = 10;
const int blueLEDPin = 11;
const int redValue = 255;
const int greenValue = 0;
const int blueValue = 0;
void setup() {
pinMode( 12, OUTPUT); 改
pinMode(redLEDPin, OUTPUT);
pinMode(greenLEDPin, OUTPUT);
pinMode(blueLEDPin, OUTPUT);
void loop() {
digitalWrite( 12, HIGH ); 改
analogWrite(redLEDPin, redValue);
analogWrite(greenLEDPin, greenValue);
analogWrite(blueLEDPin, blueValue);
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
