Arduino Photo Interrupter Module
Introduction: Arduino Photo Interrupter Module
Hi guys in this instructables we will learn how to use Photo Interrupter module with Arduino.
Photo Interrupter Module Keyes KY-010 for Arduino, will trigger a signal when light between the sensor's gap is blocked.
THe KY-010 Photo Interrupter module consists of an optical emitter/detector in the front and two resistors (1 kΩ and 33 Ω) in the back. The sensor uses a beam of light between de emitter an detector to check if the path between both is being blocked by an opaque object.
Teacher Notes
Step 1: Things You Need
For this instructables we will need following things :
Arduino uno
Jumper wires
Breadboard (optional)
Step 2: Schmatics
Connect the power line (middle) and ground (left) to +5V and GND respectively. Connect signal (S) to pin 3 on the Arduino.
KY-010 - Arduino
- (left) - GND
middle - +5V
S (right) - Pin 3
Step 3: Code
Please copy the following code and upload it to your arduino Board :
int Led = 13; // define LED pin
int buttonpin = 3; // define photo interrupter signal pin
int val; //define a numeric variable
void setup()
pinMode(Led, OUTPUT); // LED pin as output
pinMode(buttonpin, INPUT); //photo interrupter pin as input
void loop()
val=digitalRead(buttonpin); //read the value of the sensor
if(val == HIGH) // turn on LED when sensor is blocked
digitalWrite(Led,HIGH);
else
digitalWrite(Led,LOW);
Step 4: Testing Photo Interrupter Module
The arduino will light up the LED (pin 13) on the Arduino when there's an object blocking the beam of light between the sensor's gap.
Be the First to Share
    • LED Strip Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • Clocks Contest
      Clocks Contest
